kardar2 Posted September 18, 2015 Report Posted September 18, 2015 Hello all I got my book yesterday. But the first box is a ribbon box. Under materials the ribbon calls for oak , red veneer and yellow veneer. I don't know where the yellow veneer comes in at. There is no istructions on the glue up. Is the yellow veneer between the small red veneer strip and the purpleheart center strip? This would be my first ever experience with veneer. Where is a good place to buy this kind of veneer? I will look on YouTube maybe Carol has a video on the ribbon part. Thanks for your help. Karl Quote
Phantom Scroller Posted September 18, 2015 Report Posted September 18, 2015 You need a box man boxaholic Dan DWSUDEKUM he might be able to help. I'm sure you could use other woods. Roly Quote
DWSUDEKUM Posted September 18, 2015 Report Posted September 18, 2015 Thanks Roly. I was just replying to this. Karl you can indeed use different woods than are specified in the book. The book is just a guide and is meant to give you a solid foundation on which to build upon. Below is one of the ribbon boxes that I made a while back. The ribbon is made from red cedar, pine and red cedar and it is on a pine box. I try to make the ribbon fit the box as much as possible. Here are a couple of different ones This one I cut from Baltic Birch Plywood Here is another one cut from Baltic Birch Ply however this one was tinted a light pinkish color As you can imagine since we are working in wood and can vary the thickness and type(s) of wood used you can get a very wide variety of colorful ribbons. If you have any questions please feel free to ask them I will be more than happy to answer them if possible. DW Scrolling Steve 1 Quote
kardar2 Posted September 18, 2015 Author Report Posted September 18, 2015 Thanks DW, yep I know I could use other wood and I could use a white wood on a dark box such as a walnut box. But thought this ribbon looked like a good challenge. Maybe I will skip the veneer one less thing to buy I guess. Less time consuming too. Quote
DWSUDEKUM Posted September 18, 2015 Report Posted September 18, 2015 If you go to your local Woodcraft store in your case the closest looks to be in Sacramento or stop online at woodcraft.com you can purchase venier stock with no problem. DW Quote
kardar2 Posted September 18, 2015 Author Report Posted September 18, 2015 Wood craft? hmm okay did not think to look there thanks Quote
kardar2 Posted September 18, 2015 Author Report Posted September 18, 2015 Those are some pretty boxes by the way. Quote
amazingkevin Posted September 18, 2015 Report Posted September 18, 2015 Thanks DW, yep I know I could use other wood and I could use a white wood on a dark box such as a walnut box. But thought this ribbon looked like a good challenge. Maybe I will skip the veneer one less thing to buy I guess. Less time consuming too. I see you gearing up to to some new endeavors! Good for you! Boxes are addicting so be ready to make lots!I've got so many irons in the fire i don't know which way to go.I do have a box i'm interested very much in i just got the pattern for.Lets see what happens for both of us! :) :) :) :) Quote
