Hallway Posted November 8, 2009 Report Posted November 8, 2009 I finally finished cutting this pattern. I tried something a little different. I sandwiched 5 sheets of paper between two sheets of 1/8" baltic birch. When I finished cutting the pattern I had two patterns cut in wood and 5 in paper. The paper is slightly heavier stock and I used a light tan and white colors. They came out great. I will frame one up and post a picture of the paper cut so you can compare. I used a #1 spiral blade. The two wood cut outs are on the left. Quote
Hallway Posted November 8, 2009 Author Report Posted November 8, 2009 Here is a picture of one of the wood cuttings matted and ready for the frame. Quote
Marshall Posted November 9, 2009 Report Posted November 9, 2009 Hallway looks real nice from this end , the up-close really shows all the cuts and detail . Thanks for showing this , shows your real talent ........ .............Marshall Quote
Travis Posted November 9, 2009 Report Posted November 9, 2009 I agree. That turned out stunning. You did a great job on it. The paper copies are fantastic too. Nicely done! Quote
Christina Posted November 14, 2009 Report Posted November 14, 2009 Wow those all turned out wonderful. Great idea cutting paper ones at the same time. Thanks so much for sharing your work with us. Christina Quote
shadylady0447 Posted November 19, 2009 Report Posted November 19, 2009 That looks great, Hallway! I like the double matting. Nice work! Quote
Clayton717 Posted November 19, 2009 Report Posted November 19, 2009 turned out great,thanks for sharing Quote
