Mabel H. Posted October 10, 2015 Report Posted October 10, 2015 I am just getting started with the scroll saw, and am trying to make puzzles. I started with the blades I had which were to big. I ordered some puzzle blades and am breaking them pretty fast. I am using some plain 1/4 plywood to practice, and am cutting freehand. Any suggestions, speed, fast or slow, wood best to use, better blades etc. Quote
Phantom Scroller Posted October 10, 2015 Report Posted October 10, 2015 Mabel H you have to make the blade do the work don't force the wood through or they will snap try less tension and slow and if it's a puzzle for children use a No3 ultra reverse blade or even a no5 instead of the fine puzzle blade it make the pieces easier for them to put together. Do a test on a couple pieces first to see how they fit together then do the real thing after your happy. Roly Quote
ike Posted October 10, 2015 Report Posted October 10, 2015 let the saw do the work and practice . Quote
Mabel H. Posted October 10, 2015 Author Report Posted October 10, 2015 I was using a larger blade, but not sure what it was, looks like at least a 5 of some sort. Since I have the puzzle blades I will have to see if I can get the tension and speed thing worked out. Phantom Scroller 1 Quote
Lucky2 Posted October 10, 2015 Report Posted October 10, 2015 Mabel, I use the same tension on my puzzle blades, as I do on any other blade. It makes no difference to me what I'm cutting, I always use the same amount of tension on my blades. No matter if it's 1/16" thick, or, if it's 1.5" thick the tension never changes. I have never encountered anything that I would try to cut with less tension then I use now. If I did, I wouldn't have control of the blade. Maybe this is why I can't do anything with the spiral blades. Len Phantom Scroller 1 Quote
dgman Posted October 10, 2015 Report Posted October 10, 2015 I agree with Len, high tension on the blade. Low tension will cause blade breakage. As has been mentioned, let the blade do the cutting, do not force the cut. Make sure you are not applying lateral pressure on the blade when making sharp turns. Most folks use a high quality plywood like Baltic birch. I'm sure others will come on with other plywoods they use. It's great that you are cutting freehand. Jig saw puzzles look more handmade when cut freehand. Puzzle blades are typically a 3/0 skip tooth blade. If you still break them, try using a 2/0 skip tooth blade. They are a little bigger and may hold up a little better. Quote
amazingkevin Posted October 11, 2015 Report Posted October 11, 2015 (edited) I am just getting started with the scroll saw, and am trying to make puzzles. I started with the blades I had which were to big. I ordered some puzzle blades and am breaking them pretty fast. I am using some plain 1/4 plywood to practice, and am cutting freehand. Any suggestions, speed, fast or slow, wood best to use, better blades etc. Lots of factors are involved in breaking blades.Why Do Scroll Saw Blades Break? And how do I prevent it? Edited October 11, 2015 by amazingkevin Quote
rdatelle Posted October 11, 2015 Report Posted October 11, 2015 I use the puzzle blades from Mike's workshop without a problem. Have good tension and go slow or the blade will sway and cut the wood on a slight angle and the pieces won't come out. Good luck. Quote
Southern Scroller Posted October 16, 2015 Report Posted October 16, 2015 Regardless of what blade you choose, it's tough to beat practice, practice, practice. As others have said, let the blade do the work. That's all well and good but when you're starting it's not always understood. When I first started I broke a lot of blades and had lots of burns on thicker wood. With practice you will learn the feel of your saw, burns will mostly go away if not completely go away and you will realize that you haven't broken a blade in a long time. I broke a blade the other day while cutting a puzzle and it gave me a scare for a couple seconds. Realized that it hadn't happened in so long I forgot what it was like when it happens. Today I compound cut some 13/4" hardwood and it came out with not a trace of burn. I was happy. Lots of tension, let the blade do the work. It will come to you quickly. Quote
