JohnR48 Posted October 15, 2015 Report Posted October 15, 2015 I have come across a supplier for 1/8" Baltic Birch ply and would like to know which blade would be most recommended. On my last project some of the cuts were not at 90 degrees to the surface. What was I doing wrong? Thanks in advance to those who respond. Quote
Phantom Scroller Posted October 15, 2015 Report Posted October 15, 2015 (edited) John for that thickness depending on the pattern size I would use an ultra reverse no3 blade and as for the 90 deg don't go by the dial on the saw if you are not spot on in front of the line it won't be 90 deg use a protractor or a good 90 deg piece of wood or an electronic gadget on the blade as I use but you can get them cheaper. Roly . This is mine. http://www.amazon.co.uk/Digital-Protractor-Inclinometer-Leather-Batteries/dp/B001YJ8F8K/ref=sr_1_35?ie=UTF8&qid=1444934363&sr=8-35&keywords=digital+electronic+measure Edited October 15, 2015 by Phantom Scroller Falcon 1 Quote
fredfret Posted October 15, 2015 Report Posted October 15, 2015 John, I use #1 or 2/0 for 1/8th inch BB. To check 90 deg take a piece of 3/4 or thicker wood cut a straight line in about 1/4 inch. back the blade out abd turn over the wood now see if the BACK of the blade will go in. If not your blade and table are not at 90. This is a fairly cheap and easy way to check. Good Scrollin. Fredfret Wichita, Ks Quote
LarryEA Posted October 15, 2015 Report Posted October 15, 2015 In General Scroll Sawing, where you posted this topic, search for "Squaring Blade" Enter this in the top right where it says 'Search This Topic ' This has been discussed a few times before Quote
Sparkey Posted October 15, 2015 Report Posted October 15, 2015 I use FD new 3/0 spiral for all my plywood cutting. Quote
Jason Posted October 15, 2015 Report Posted October 15, 2015 I use fd superior puzzle for ¼" and under. Quote
WayneMahler Posted October 15, 2015 Report Posted October 15, 2015 I use #1 or #3 Ultra Reverse for this. Also if you have small pieces to cut, use a zero clearance block to protect the piece from breaking. A playing card taped down around the blade works wonders for this. Quote
KurtP Posted October 15, 2015 Report Posted October 15, 2015 I had the same problem once with my dewalt, the dial was on zero but when I used a protractor I found that I had to set it about 1/2 a degree to get it a 90 degrees. Now when ever I move the table I make sure to check. Quote
amazingkevin Posted October 16, 2015 Report Posted October 16, 2015 In an emergence you can use a credit card or a business card,standing on edge and next to the blade to check for 90 degree true ness.!/8" i would use #3 or smaller blades.And run slow speed and press down to hold the wood and have great control cutting. I have come across a supplier for 1/8" Baltic Birch ply and would like to know which blade would be most recommended. On my last project some of the cuts were not at 90 degrees to the surface. What was I doing wrong? Thanks in advance to those who respond. Quote
JohnR48 Posted October 16, 2015 Author Report Posted October 16, 2015 The table is 90 degrees to the blade. Just some of the cuts were not 90 degrees to the top surface of the wood. Quote
Lucky2 Posted October 16, 2015 Report Posted October 16, 2015 Well then John, I think that either your blade doesn't have enough tension on it, or, your forcing the cut which can cause the blade to bend. One other thing, it could be that your blade is not sharp enough also. Len Phantom Scroller 1 Quote
MrsN Posted October 16, 2015 Report Posted October 16, 2015 I very rarely cut a single layer of 1/8" material. I prefer a stack of 2 or 3 pieces. I most often use a #3 blade, but it really depends on what I am cutting. Lucky2 1 Quote
NC Scroller Posted October 19, 2015 Report Posted October 19, 2015 Unless I am scrolling a picture I use Flying Dutchman Ultra Reverse blades for Baltic Birch. Sizes vary from #1 to #5. Depending on the pattern I might use two or three different sizes on one project. The more delicate the area the smaller the blade. If a picture I will use # 2/0 or # 1 spirals. Also I seldom cut single pieces of 1/8 BB. I like to stack at least 3 or 4 high. Quote
JohnR48 Posted October 19, 2015 Author Report Posted October 19, 2015 Thanks Katie and Scott. Your last sentences were what I was inquiring about mostly. Quote
DWSUDEKUM Posted October 19, 2015 Report Posted October 19, 2015 I have come across a supplier for 1/8" Baltic Birch ply and would like to know which blade would be most recommended. On my last project some of the cuts were not at 90 degrees to the surface. What was I doing wrong? Thanks in advance to those who respond. John, For 1/8 inch BB I would use a #3 Ultra reverse this will help reduce tearout and the fuzzies. As for your last couple of projects having cuts that were not 90 degrees that could be several things. It could be that when you are cutting you are applying sideways pressures and actually bending the blade out of position. Another reason might be that the saw itself is out of square. That is the blade is not square to the table. This is not hard to check periodically. Practice will help keep those cuts square. DW Quote
