LarryEA Posted October 17, 2015 Report Posted October 17, 2015 (edited) In a camera, pixels make a digital picture. So what is the name for the holes in a scroll saw pattern? The holes make the picture. Are they SHOLES (Scroll Holes?) Just asking? ********************************************************************************************************************************* ************** Read further down, Dan and Scott give the answer. Edited October 17, 2015 by LarryEA Quote
Phantom Scroller Posted October 17, 2015 Report Posted October 17, 2015 (edited) Holes they're holes...................drill holes. I'M JUST SAYING! Edited October 20, 2015 by Phantom Scroller LarryEA 1 Quote
amazingkevin Posted October 17, 2015 Report Posted October 17, 2015 Pilot holes In a camera, pixels make a digital picture. So what is the name for the holes in a scroll saw pattern? The holes make the picture. Are they SHOLES (Scroll Holes?) Just asking? oneleggimp 1 Quote
NC Scroller Posted October 17, 2015 Report Posted October 17, 2015 Per the dictionary it is Fretwork: noun 1.ornamental work consisting of interlacing parts, especially work in which the design is formed by perforation. 2.any pattern of dark and light, such as that of perforated fretwork. oneleggimp and LarryEA 2 Quote
LarryEA Posted October 17, 2015 Author Report Posted October 17, 2015 Thank you Dan and Scott. I thought there might be a name but never occured it was "FRET" Frets. Per the dictionary it is Fretwork: noun1.ornamental work consisting of interlacing parts, especially work in which the design is formed by perforation. 2.any pattern of dark and light, such as that of perforated fretwork. Quote
merlin Posted October 17, 2015 Report Posted October 17, 2015 who cares they are holes to cut the product...I mean without holes you are going no where................Just saying............. oneleggimp 1 Quote
heppnerguy Posted October 18, 2015 Report Posted October 18, 2015 I call them SOB's because they are the things that make all those nasty 'frizzies", I have to work to get rid of when I am finished cutting all of them our Dick heppnerguy LarryEA and keefie 2 Quote
NC Scroller Posted October 18, 2015 Report Posted October 18, 2015 I call them SOB's because they are the things that make all those nasty 'frizzies", I have to work to get rid of when I am finished cutting all of them our Dick heppnerguy Dick I seldom have "frizzies" because I use the FD Ultra Reverse Tooth blades. When I do I like to burn them off with a pin torch. oneleggimp and LarryEA 2 Quote
Southern Scroller Posted October 18, 2015 Report Posted October 18, 2015 (edited) Ok. Please tell me what is a pin torch and if it makes life easier (less sanding) where do I get one? I realize I'm probably the only one here that doesn't know of a pin torch so please help me rid myself of this ignorance. Dick I seldom have "frizzies" because I use the FD Ultra Reverse Tooth blades. When I do I like to burn them off with a pin torch. EDIT: Google is my friend. Talk about overkill! To each his own. Fun with tools! EDIT AGAIN: Wait! Google is still my friend. I searched p-E-n instead of p-I-n and found it. I want one! The p-I-n involved big stuff like gas bottles of O2 and C2H2 shown on YouTube videos. Cool stuff like leather sleeves, safety boots, shields and other things no fun to wear in the summer. Edited October 18, 2015 by Southern Scroller LarryEA 1 Quote
heppnerguy Posted October 19, 2015 Report Posted October 19, 2015 With a hard wood I don't have very many fuzziness either but with BB ply I get some and also some breakouts when the piece has several hundred really close and small holes like with a fret clock or when I cut the Eiffel Tower. My go to blade For 1/8 to 1/4 inch is a double tooth/reversible. Usually pretty good with normal holes and frizzies but for thinker hard wood I often use scrollsaw rev. Skip tooth blade. I was amazed when I cut what I consider a pretty fragile piece and used an orbital sander on it with no breakage. Dick heppnerguy LarryEA 1 Quote
Young_Scroller Posted October 19, 2015 Report Posted October 19, 2015 Dick I seldom have "frizzies" because I use the FD Ultra Reverse Tooth blades. When I do I like to burn them off with a pin torch. Not sure I understand, how do you use it to remove the frizzies on the back exactly? Quote
Sparkey Posted October 19, 2015 Report Posted October 19, 2015 You just touch the fizzles around the edges with the flame and they burn off leaving a clean smooth edge. I do the same thing with all of my fretwork. Quote
keefie Posted October 19, 2015 Report Posted October 19, 2015 Not sure I understand, how do you use it to remove the frizzies on the back exactly? The FD ultra reverse blades have every third tooth reversed, two teeth cut on the down stroke and one on the up stroke. It leaves your work with almost no frizzies to get rid of ( sometimes with no sanding needed either) Quote
Young_Scroller Posted October 20, 2015 Report Posted October 20, 2015 You just touch the fizzles around the edges with the flame and they burn off leaving a clean smooth edge. I do the same thing with all of my fretwork. thanks for clearing that up for me The FD ultra reverse blades have every third tooth reversed, two teeth cut on the down stroke and one on the up stroke. It leaves your work with almost no frizzies to get rid of ( sometimes with no sanding needed either) Thats good to know, thanks for the info Quote
heppnerguy Posted October 20, 2015 Report Posted October 20, 2015 You can also use a stiff brush to remove the frizzies. This tip was given to a grandfather by his young gtanddaughter.. i loved that part of the hint.. was not given to me, someone else posted it here about 8 months ago or so Dick heppnerguy Quote
keefie Posted October 20, 2015 Report Posted October 20, 2015 You can also use a stiff brush to remove the frizzies. This tip was given to a grandfather by his young gtanddaughter.. i loved that part of the hint.. was not given to me, someone else posted it here about 8 months ago or so Dick heppnerguy Yep, a toothbrush works well, but don't use the one you clean your teeth with as it doesn't taste nice afterwards (I know this as Rob Roy told me lol :roll: ) dgman 1 Quote
Rob Roy Posted October 20, 2015 Report Posted October 20, 2015 Yep, a toothbrush works well, but don't use the one you clean your teeth with as it doesn't taste nice afterwards (I know this as Rob Roy told me lol :roll: ) Well Keith, I cant use my toothbrush for the fuzzies, I left my toothbrush in the hospital. I'll need to buy a new one now, and being a Scot that upsets me a greatly. The hospital visit,(amongst other problems), was the reason for being A.W.O.L for a wee while. Although the b****red up left arm is still giving trouble. . Rob Roy. keefie 1 Quote
heppnerguy Posted October 21, 2015 Report Posted October 21, 2015 Yep, a toothbrush works well, but don't use the one you clean your teeth with as it doesn't taste nice afterwards (I know this as Rob Roy told me lol :roll: ) Actually, I too use a tooth brush, but it is a large stiff one use for cleaning false teeth. it works pretty well for me.. Dick keefie 1 Quote
