jerry1939 Posted October 17, 2015 Report Posted October 17, 2015 Hi. Don't know if I will have guts enough to try coin cutting, but IF I do here are some basic questions; 1. What blade do you use & an approximate blade speed. 2. What readily available coin in the U.S. would you recommend for a first timer with 3 thumbs (That's just one hand.) 3. Do I assume that you make a zero clearance table top? Any and all advice greatly appreciated. jerry Quote
dgman Posted October 17, 2015 Report Posted October 17, 2015 Jerry, go over to Works In Progress & Tutorials and check out Hotshot's tutorial on coin cutting. He's the expert. Quote
amazingkevin Posted October 17, 2015 Report Posted October 17, 2015 Hi. Don't know if I will have guts enough to try coin cutting, but IF I do here are some basic questions; 1. What blade do you use & an approximate blade speed. 2. What readily available coin in the U.S. would you recommend for a first timer with 3 thumbs (That's just one hand.) 3. Do I assume that you make a zero clearance table top? Any and all advice greatly appreciated. jerry here ya goLove Birds - Coin Cutting Tutorial Quote
