Hi Marg.
                 Thanks for showing. I can't remember that one as I delete them after doing them but I'm not happy with the nose could do with a bit more pronounce definition. So I don't know what you changed if your happy then that's find by me. Roly
I changed the chin and  part of the mouth from lots of small cuts to longer ones, and the shirt.  Didn't take much notice of the nose until it was finished and framed, then I thought that it looked a bit piggy.
Here is a copy of the pattern  and a copy of the photo
Edited by wombatie
Hi Marg.
Roly is there any way to fix the nose?  Just wondering.
Marg
Marg
Marg I've been out of commission for a few days with flu I'll have a look at it and do some plastic surgery. Watch this space. Roly
I know you can't put things back but you can take things out, so draw the difference with a pencil until your happy you see the nose shape but the bits under the nose was the moustache highlighted which is what you could have done without unless you add a couple more lines to add the moustache up to you, see the nose first. I though about sticking nose pattern over the nose but you won't get it the right size without a lot of fiddling, hence the pencil. Hope this works Marg. Roly
Edited by Phantom Scroller
  • 2 weeks later...
