bandaideman Posted October 31, 2015 Report Posted October 31, 2015 Those of you with an EX 21, how often do you find you need to replace the white tension lever on the front. I had the original start letting go when scrolling and found I was putting it back 2-4 times during the cut. I got a new one and replaced not to long ago and now am having the same issue not as much right now but will let go on me. I have adjusted as it instructs on the replacement. I ordered a new one last night and will be here next week. I am not ready to change yet but if it gets like the original I will have it on hand. It seems like I replaced it less than a year ago. Anyone else replacing the switch. I know there is normal wear and tear but this time did not seem to be very long. Could something have to do with the upper blade holder? Any thoughts would be appreciated Thank you. Quote
Scrappile Posted October 31, 2015 Report Posted October 31, 2015 I have had my Ex for about 2 years have not changed it yet. Seems to be holding up fine. I put a little vaseoline on it from time to time. Seem like I read to do that some where. I bought a spare right after I bought my saw because I thought it looked like something that would wear out. But not yet. You might call Seyco and ask the question. I have always found them eager to help and advise. WayneMahler 1 Quote
Docupton Posted October 31, 2015 Report Posted October 31, 2015 When it happened to me I held it in place with an elastic band till a replacement arrived, worked well. Quote
terrylee Posted October 31, 2015 Report Posted October 31, 2015 Yes,I had my for about a year half and I had change it once so far,but I use it lot So I don't know if that normal or not amazingkevin 1 Quote
trackman Posted October 31, 2015 Report Posted October 31, 2015 I got a new one from seyco. They redo the level so it locks in place a lot better than the one from the factory and I have had mine for over a year an it still locks like new. amazingkevin 1 Quote
jerry1939 Posted October 31, 2015 Report Posted October 31, 2015 I have a Delta, but this might apply to you also. Read on this site some time ago about BLADE SLIPPAGE. One of the suggestions was to sand the ends of a new blade. I made a "paint stir stick", sprayed both sides with adhesive and wrapped it with medium/fine sandpaper on 2 sides. Have yet to have a blade slip out. My first thought is that you might have the same tendency as I do. OVER TIGHTENING the clamp. jerry Quote
Scrolling Steve Posted October 31, 2015 Report Posted October 31, 2015 Had mine for a year and half and put a dab of white lithium grease on it every two weeks .....Still works fine. Quote
Terry Jay Posted November 1, 2015 Report Posted November 1, 2015 I have had the EX21 for about 6 years and have never had the white over-center lever slip..I have a spare lever assembly and spare upper and lower blade clamps. Have replaced the lower blade holder several times. It gsts 50 or more times use than the top one. I do have to rplace the inserts on the knob screws and th set screws regularly, as well as sand them square from time to time. Terry Quote
amazingkevin Posted November 1, 2015 Report Posted November 1, 2015 Guess i'll stick with the DW788,So far all the fixes were just re tightening things or replace a bolt or re grease everything.I gave one away and still have three. ;)I'm not greedy i just want to scroll when i want to scroll ,no down time . Quote
amazingkevin Posted November 1, 2015 Report Posted November 1, 2015 Those of you with an EX 21, how often do you find you need to replace the white tension lever on the front. I had the original start letting go when scrolling and found I was putting it back 2-4 times during the cut. I got a new one and replaced not to long ago and now am having the same issue not as much right now but will let go on me. I have adjusted as it instructs on the replacement. I ordered a new one last night and will be here next week. I am not ready to change yet but if it gets like the original I will have it on hand. It seems like I replaced it less than a year ago. Anyone else replacing the switch. I know there is normal wear and tear but this time did not seem to be very long. Could something have to do with the upper blade holder? Any thoughts would be appreciated Thank you. I missed an ex30 for $700 brand new ,grrr! Quote
Lucky2 Posted November 1, 2015 Report Posted November 1, 2015 Dan, I've owned my EX21 for over six years, and it gets used on a regular basis. Over all of these years I've never had an issue with my saw, and I've never had to replace any levers or knobs either. The only thing that I adjust is the set screws that go up against the blade in the blade holder. If it is the flip lever on the front of the saw that is the issue, I would think that you might have the tension adjuster that is on the back of the saw set to tight. When I first got my saw, I was guilty of doing that and the front tension lever would flip up every so often while cutting. It was very frustrating, but, eventually I figured it out and I starting using a little less tension from the rear clamp. Since then, I've had no issues with my saw. Len Quote
Phantom Scroller Posted November 1, 2015 Report Posted November 1, 2015 The only time it happened to me was when I put a seven blade in I changed it to a 5 never happened again it seems it's a tension thing plus I use a silicone WD40 spray on the lever mechanism. Roly. Quote
bandaideman Posted November 1, 2015 Author Report Posted November 1, 2015 Thanks to all I will check all those things. From reading it is most likely the tension in the back. I will let up on it and see what happens. I have had issues with that also in that as I scroll for a while it will increase the tension by it self. the white line on the nob starts in one place then will move clock wise as I saw. It seems to have stopped that now. Quote
