savethebeer Posted November 12, 2015 Report Posted November 12, 2015 Here is my last rant. This was done with my old saw so I had changed nothing. What happened was I discovered [after 3 years of scrolling ] repositioning spray. Up to now I have used a spray glue on my patterns that was a heavier spray than you lot recomend. The heavier spray worked for me for 3 years, pattern stuck solid to the masking tape after about 5 minutes. I had always looked at repositional spray over the years and thought that I was not going to waste money when the glue I normally used was half the price. Last week I found repositional spray that was half the normal price so I bought it. Then I tried the difficult pattern attached and the paper pattern just lifted off the wood. I then taped the pattern to the wood with cellotape but it still lifted badly. I managed to complete the pattern by being careful but............................... I have never experienced lifting of patterns as bad as this and I know it would not have happened with my normal glue. Quote
LarryEA Posted November 12, 2015 Report Posted November 12, 2015 (edited) I would suggest you quit saving the beer, relax and have one. Remember what Forest Gump said,: " It Happens! " Edited November 12, 2015 by LarryEA Scrolling Steve and WayneMahler 2 Quote
ike Posted November 12, 2015 Report Posted November 12, 2015 I have not had that problem. Did you use Krylon Adhesive all purpose 7010? Quote
WayneMahler Posted November 13, 2015 Report Posted November 13, 2015 I use 3m 77 and don't have this problem. I also cover my projects with blue painters tape then attach the pattern to it. Quote
trackman Posted November 13, 2015 Report Posted November 13, 2015 I use the 3m 77 also. Tape the wood with blue tape, spray the TAPE not the paper than cover with clear packing tape. I spray the tape and not the paper so I don't get glue on my hands that away. Quote
bandaideman Posted November 13, 2015 Report Posted November 13, 2015 I think if you use the glue and put the pattern on the masking tape or equivalent and It stays put to cut and you can get the masking tape off with the pattern without residue then you have your answer use the glue. Glue patterns on the wood ends in more work with residue. I do as the others above and usually have little or no problem but other times it is huge problems. Just have to stop and tape with clear tape and go on. Repositionable glue does come in varying stickiness and some are like real weak. But for less frustration continue with you glue. With the new glue use on non fret work patterns. Quote
terrylee Posted November 13, 2015 Report Posted November 13, 2015 I use Locktight 100 and is 4. something for a can.I been using it for years and I have never had a problem with it,unless you leave on the wood to long,then you have a problem of pattern sticking to the wood.You have a time frame of 10 mim before it really sticks Quote
crupiea Posted November 13, 2015 Report Posted November 13, 2015 Way , way too much glue. i use spray glue for my patterns. i spray a maximum and I mean maximum of 1 second for the whole sheet. I then wil turn the sheet glus side up and feel it. if its tacky, its too much and will cause trouble. i wait until its barely tachy and then put in on the wood. you have to think that you are only needing it to sticj for one pass so once the blade has cut past it, oh well, it can fall off all day long. less is always more. way less. Quote
amazingkevin Posted November 13, 2015 Report Posted November 13, 2015 Way , way too much glue. i use spray glue for my patterns. i spray a maximum and I mean maximum of 1 second for the whole sheet. I then wil turn the sheet glus side up and feel it. if its tacky, its too much and will cause trouble. i wait until its barely tachy and then put in on the wood. you have to think that you are only needing it to sticj for one pass so once the blade has cut past it, oh well, it can fall off all day long. less is always more. way less. I never tried that way! :cool: :cool: :cool: Quote
Phantom Scroller Posted November 13, 2015 Report Posted November 13, 2015 I use spray re-positional glue from HOBBYCRAFT and 2" sellotape on top never fails me. Roly Lucky2 1 Quote
Lucky2 Posted November 13, 2015 Report Posted November 13, 2015 STB, I use Elmers multi purpose mounting spray, it is a repositionable glue. I have never had any problems with it, unless it was user error. Sometimes I'm a little over generous with the spray button, and the pattern sticks to well. For those instances, I use mineral spirits to soak the paper and excess glue to wipe it off. In your picture, it looks as if you haven't used enough glue. If your not familiar with the spray glue that can happen, but, once you get used to using it, your problem will be solved. There is quite a difference in spray glue types, some of it is to be used to permanently attach one item to another. Repositionable spray, is used so that you can remove one item from another with not much diffculty. If you use the repositionable type, it can take a bit of getting used to how much is enough. It's a trial and error type of thing. Once you get used to using it, you'll wonder how you ever survived without it. Len Phantom Scroller 1 Quote
danny Posted November 13, 2015 Report Posted November 13, 2015 Just have to reply....Have tried many methods. All boiled down to using the 3m-77 spray glue. Normal spray. Once over. Apply to Bare wood. No tape etc. Holds excellent till that final cut. Then spray a bit of Mineral Spirits Might have to wait for a minute and the pattern lifts off in one piece. Clean wood with a bit more spitits on a rag and let dry for a hour. Ready to go. And this is only my 2 cents worth. Danny :+} Quote
Bpardue Posted November 13, 2015 Report Posted November 13, 2015 I do the same as Danny with no problems on soft woods, hardwoods that burn easy I wrap with clean tape than apply the pattern over the tape but no issues. I think you either waited to long before sticking the pattern or did not use enough glue brian Quote
ONELUNG Posted November 14, 2015 Report Posted November 14, 2015 Since 1998 I have used Elmers spray glue on all my patterns.No problem here buy it by the case cheaper that way Jerry Quote
Sam777 Posted November 14, 2015 Report Posted November 14, 2015 Hi all, I am the newest guy here. Please be patient with my questions So, is it better to spray the glue directly onto the wood or use the tape method. The tape method sounds like costly. how wide of a blue tape do you use? Thank you sam Quote
Scrappile Posted November 14, 2015 Report Posted November 14, 2015 Hi all, I am the newest guy here. Please be patient with my questions So, is it better to spray the glue directly onto the wood or use the tape method. The tape method sounds like costly. how wide of a blue tape do you use? Thank you sam Probably one of the most discussed topics on this forum. To me it all boils down to personal preference. Search "glue" or "tape" here and there should be hundreds of posts. Personally I do it both ways, and it depends on what I am cutting. Very fragile pictures I use painters tape because I feel it helps hold things together. Less fragile I do not use the tape. I never use the clear tape over the pattern anymore, that did not work for me. Quote
LarryEA Posted November 14, 2015 Report Posted November 14, 2015 Hi all, I am the newest guy here. Please be patient with my questions So, is it better to spray the glue directly onto the wood or use the tape method. The tape method sounds like costly. how wide of a blue tape do you use? Thank you sam Just as Paul said. Many methods.... I use 'Glad Press N Seal' from the grocery store, not blue tape. So you see, there are many ways... do that search........ Quote
dgman Posted November 14, 2015 Report Posted November 14, 2015 Hi all, I am the newest guy here. Please be patient with my questions So, is it better to spray the glue directly onto the wood or use the tape method. The tape method sounds like costly. how wide of a blue tape do you use? Thank you sam It's best to asks a question in a new post so as not to hijack the original post. Quote
LarryEA Posted November 14, 2015 Report Posted November 14, 2015 Thank you sam It's best to asks a question in a new post so as not to hijack the original post. Golly Dan, He's still talking about glue. Probably better you sent him a pm. Savethe brew didn't complain.... correction.... this post started as a complaint, hijacked into a discussion of spray glue intersected with blue painters tape and me!!!~ worst of all talking about Forest Gump. I'm more quilty of a Quote
dgman Posted November 14, 2015 Report Posted November 14, 2015 Golly Dan, He's still talking about glue. Probably better you sent him a pm. Savethe brew didn't complain.... correction.... this post started as a complaint, hijacked into a discussion of spray glue intersected with blue painters tape and me!!!~ worst of all talking about Forest Gump. I'm more quilty of a Maybe I should rephrase, to get more responses to your question, it's best to start a new post.Is that ok with you Larry? Quote
Sam777 Posted November 14, 2015 Report Posted November 14, 2015 Thank you Dan, Sorry guys. I didn't mean to hijack the topic. This shows my lack of experience in Forums Discussions. Sam Quote
LarryEA Posted November 14, 2015 Report Posted November 14, 2015 Maybe I should rephrase, to get more responses to your question, it's best to start a new post. Is that ok with you Larry? Yes Dan, new topic, new post. Quote
