OLD WORMY Posted November 16, 2015 Report Posted November 16, 2015 My type 1 DW 788 is about 15 years old and needs a general overhaul that replaces worn parts and brings it to like new condition. The local Dewalt factory service center has qouted me a maximum price of $259 to perform this overhaul they call their GRC service. It could be less depending upon the actual parts replaced. Has anyone had this done and are you satisfied with the results? I am leary of spending half the price of a new one to fix my old saw although I would prefer my type 1 to a new type 2. The saw still runs great but is showing some signs of wear and needs a tune up. What do you think? Quote
ike Posted November 16, 2015 Report Posted November 16, 2015 as a rule those cost are for replacing a motor or a circuit board My type 2 is in the shop now because it shorts out and blows a fuse that is the information that they gave me.I had it in one other time and it was $40 It's a chance I take. My type 1 is still running good.It was rebuilt a year before I bought it, Quote
amazingkevin Posted November 16, 2015 Report Posted November 16, 2015 My type 1 DW 788 is about 15 years old and needs a general overhaul that replaces worn parts and brings it to like new condition. The local Dewalt factory service center has qouted me a maximum price of $259 to perform this overhaul they call their GRC service. It could be less depending upon the actual parts replaced. Has anyone had this done and are you satisfied with the results? I am leary of spending half the price of a new one to fix my old saw although I would prefer my type 1 to a new type 2. The saw still runs great but is showing some signs of wear and needs a tune up. What do you think? My dw type 1 took lots of abuse from me I decided to re grease all the bearings i could except 2 with Valvoline synthetic grease.2 bearings needed to be pressed out so i didn't want to be with out a saw so i left them alone .The saw was very sloppy before the grease job ,now over a year later it's still going strong and pulling blade tension at 1.5 to 2 consistently .Repack the bears isn't hard and well worth the benefits Go for the do it your self job and buy grosses of blades with the money you save!Plenty of u-tube videos on the dw 788 break down available! Just "Google"what you want to know! oneleggimp 1 Quote
ike Posted November 16, 2015 Report Posted November 16, 2015 The type 1 I would pay that price being an owner of both. JJB 1 Quote
fredfret Posted November 16, 2015 Report Posted November 16, 2015 Gwinnett Woodworkers made a video some time ago showing how to overhaul a 788. I know it is on Youtube. I have it bookmarked at home but alas I'M at work. I would at least look at it before I spent 250 bucks. If I could do it myself for 50. Let us know what happens. Good Luck Fredfret Dw788/BM-26(RBI) Wichita, Ks JJB and oneleggimp 2 Quote
NC Scroller Posted November 17, 2015 Report Posted November 17, 2015 Be very careful my SSV friend. A scrolling buddy of mine did this rebuild deal. What he got back was a Type 2 with his original tag off the motor. oneleggimp 1 Quote
browders Posted November 17, 2015 Report Posted November 17, 2015 This begs another question in my mind. Many on this site seem to be critical of the DeWalt type 2. It's what I have and having never used a type 1, have nothing to compare. Is there a significant difference in performance? Am I missing out on a nirvana scrolling experience by having a type 2? Enquiring minds would like to know. Jim Quote
JustLarry Posted November 17, 2015 Report Posted November 17, 2015 (edited) Here's the video: Larry Edited November 17, 2015 by JustLarry oneleggimp and JJB 2 Quote
orangeman Posted November 17, 2015 Report Posted November 17, 2015 I've exercised the $259 rebuild option several times, mostly with success. However I have found the saw only lasts me another 2 years before it has to go in again, usually for a different problem. The last time however was a different situation. The saw came back worse than when it went in. Discovered that an inexperienced tech had worked on it. So they gave me a brand new saw for the $259! BUT that saw turned out to be defective!I will try a different brand next time I need to buy a saw. Probably an Ex since Woodcraft sells them locally. Quote
ubgoofy2003 Posted November 25, 2015 Report Posted November 25, 2015 (edited) Jim, I have had my #2 for 7 yrs. now & just made some adjustments & replaced the blade holders on mine. If you are a production type scroller, it may make a difference. I only use mine for hobby & some commission jobs. Some owners complain of the blade movement forward & back which causes problems with corner turns. I mostly use spiral blades, so I don't have that problem. Take Care Edited November 25, 2015 by ubgoofy2003 Quote
rip Posted March 19, 2024 Report Posted March 19, 2024 (edited) i can not control the speed of the saw speed dial does not change the speed Edited March 19, 2024 by rip Quote
OCtoolguy Posted March 20, 2024 Report Posted March 20, 2024 1 hour ago, rip said: i can not control the speed of the saw speed dial does not change the speed You might want to start a new topic. This one is 9 years old. NC Scroller 1 Quote
barb.j.enders Posted March 20, 2024 Report Posted March 20, 2024 13 hours ago, rip said: i can not control the speed of the saw speed dial does not change the speed Check out the videos from Bob Brokaw here. https://www.gwinnettwoodworkers.com/ OCtoolguy 1 Quote
JJB Posted March 20, 2024 Report Posted March 20, 2024 On 11/16/2015 at 8:40 PM, browders said: This begs another question in my mind. Many on this site seem to be critical of the DeWalt type 2. It's what I have and having never used a type 1, have nothing to compare. Is there a significant difference in performance? Am I missing out on a nirvana scrolling experience by having a type 2? Enquiring minds would like to know. Jim There is a difference. I have a type 2 made in Taiwan, and the Type 1 was made in Canada. After I started teaching at my local woodworking store, I was able to use a Type 1 and i definitely noticed the difference. They run smoother and quieter and the cut quality was better also. I wouldn't say it was a nirvana experience but I feel like the Type 1 just performs better overall. If you are ever able to try one out I suggest you do. Now I am just trying to figure out how I can switch out my saw for one of the classroom saws. heh heh. OCtoolguy 1 Quote
JJB Posted March 20, 2024 Report Posted March 20, 2024 On 11/17/2015 at 8:21 AM, orangeman said: I've exercised the $259 rebuild option several times, mostly with success. However I have found the saw only lasts me another 2 years before it has to go in again, usually for a different problem. The last time however was a different situation. The saw came back worse than when it went in. Discovered that an inexperienced tech had worked on it. So they gave me a brand new saw for the $259! BUT that saw turned out to be defective! I will try a different brand next time I need to buy a saw. Probably an Ex since Woodcraft sells them locally. Dewalt has progressively gotten worse quality wise in the last 10 years which kind of makes me sad. they used to be the top of the mid-range priced tools. 10 years ago you knew you were getting quality, now it is hit or miss. OCtoolguy 1 Quote
Wooden Lace Posted March 21, 2024 Report Posted March 21, 2024 The Gwinnett video in very good. I contacted them and for a $20 donation to the group, they sent it to me on a DVD. Not sure if they still do that, as it's been years. Quote
