I just finished this old mill pattern and swear I will never do it again. The siding on the building was so fragile I had to tape the already cut part together to keep it from flopping. I did have one piece brake out and was going to try to put a piece in, but wife says it an old building and could have siding missing, so not sure what I'll do yet. Time to start building frames again, thanks for looking. Mike
To be sure that is a very fragile pattern as was most of Jeff's!  When ever I cut one of his or Charles's patterns I generally had to turn them over and use some scotch tape and tape the waste into position to help with supporting the next cuts. If only cutting one rather than stack cutting, you can place the tape on top.
 You do have a cutting you can be proud of and as far as the piece missing only you will know where it is! Great job!
Erv
I can see where that would get to you and never want to do another. I did a train bout a month ago and I know that I am not up to doing that one, You did a wonderful job on that one You can be proud.
I'd have never though anything about the board that fell off till you brought it up.What the customer doesn't know won't hurt them.This is a real work of art!
You did a very impressive job of that Mike.  I agree with your wife.  I have that pattern but I have never been game enough to cut it, don't think I ever will.
Marg
