Hi Folks
Chick question here :) Is there any difference to cutting a hole to suit a 1 7/16" (35mm) clock insert with the scroll saw as opposed to using a forstner bit?
Thanks in advance!
Cheers
I make a lot of clocks with fit- ups or clock inserts. I always use a forstner bit to make the insert hole. I have been scrolling for around twenty years and I won't take the chance of miss cutting the hole. If it's to small, you have to sand it. If it's to big, the insert won't stay in.
You can control the depth of the hole also. I never cut all the way through the wood blank. It looks cleaner that way.
Good luck and let us see your project!
I have always cut them with the scroll saw but perhaps I will splurge for a bit.  They are a little spendy and I do not do a lot of clocks. but what the heck, I have the  money so why not ? I am a slow learner, and now I will take one more really slow step and indulge.  after all, if the family agrees this strongly on the bit, who am I to hold out.
Dick
heppnerguy
Forstner bits are expensive especially in the larger sizes.  Anyone use a circle cutter simiuar to this type?  It is adjustable for various size clock inserts.  I use to have one, not this one, but same principal and it worked pretty well.
Edited by Scrappile
Thank you all for your advice and input.
I'll be using my scroll saw - finding a forstner bit locally is as rare as rocking horse droppings, so I'll cut it shy and sand!! I will post the project - after cutting the hole then after the fit-up. It's not an overly huge hole and with very little experience in cutting a full circle; this is going to be a great learning curve albeit a continuous one  :lol:
Thanks again. Happy scrolling!!
LarB
LarB
Given that you're going to use the scroll saw, let me suggest one more option. You can make a simple circle cutting jig to use on the scroll saw. I did that for Christmas ornaments years ago. The advantage of a jig is that you'd get a near perfect circle and it's repeatable. Finally, a shop made jig is adjustable you can cut a 35mm circle and change the circle size by moving the pivot point relative to the blade. On the other hand, for a single circle it may not be worth the effort.
Good luck with the project I know we'll all be looking forward to pictures.
Paul.
   I do have one of these  but I have never used it.  maybe I will give it a try and see how well it works. I will let you know,if I remember
Dick
I have this tool. Works pretty darn well. And it is much, much cheaper than forstner bits However, and its a huge however, you just have to be careful and use a slow rpm and a slow feed rate due to it being a single tooth cutter. You also will need a scrap price of lumber underneath it.
  • 1 month later...
Happy New Year to you all ... I'm back  :cool:   didn't go away ... was tied to the workshop/kitchen/workshop!! Here's an update... I couldn't find a forstner bit so attempted the hole with my scrollsaw - wasn't too bad but needed a heck of a lot of sanding. Ahah...I'll use the Dremel :lol:big oops, big gap! Note to self - dingbat, slow the speed down!!
Attempt 2 ... different timber and still no forstner bit, so with a little amber liquid tempter I asked he who ought to listen ;) if I could please borrow his skill with the hole saw and drill. Too easy, about 3mm too small a hole though and even more sanding. No amount of amber liquid tempter would persuade him to do this  :D So this time I did it manually...I am so glad I did because I'm really chuffed with the result. My younger Bro liked his Christmas present!
I'll post the completed project in my gallery along with the other Christmas gifts made.
Thanks again though to you all for your advice and I will be investigating the jig concept as well as the circle cutter.
Frequently, in thin wood a Forstner bit isn't always the best choice because the spur and edge cutters cut deeper than the actual hole, and can come out through the back of the wood if the hole is drilled slightly too deep. I've been using a template guide that I made from 1/4" Lexan that I stick in place with double sided tape. I then use my laminate trimmer router with a guide bushing to ride around the inside of the template and a 1/4" straight bit in the router to cut the hole the exact depth that I need with no spur marks or edge scoring. I have made a few of these holes in wood so thin that the backside of my work would allow light to be seen through it, if held up to my shop ceiling lights. Having tried using the scroll saw and the Forstner bit methods, I much prefer using my router method.
Charley
Edited by CharleyL
