Hi everyone. I have a quick question: When you arent using your saw for a couple of weeks how should you leave it: with a blade fully tensioned or without a blade. Im a little curious because I wont be using my saw very much in the next month or so. Thanks!
-Joe
Joe, I always release the tension on my blades, when I'm done using my saw daily. But, if I know that I'm not going to be using my saw for days, I even remove the blade from the blade holder. I see no reason to leave the saw or blade under pressure, when not in use.
Len
Edited by Lucky2
thanks for the replies, so it wont do any bad if i leave a blade in?
Well, that would depend upon what brand of saw your using. If your using a Dewalt or an Excaliber, you could be doing damage to the tip of the screw that holds the blade in place. On both these saws, the tips of these screws have a small insert that rotates when tightening up against the blade. It does this, so that the blade doesn't bend at the top from the screw rotating against it. If you leave the blade in place when the saw is not being used, your leaving the pressure on this tip. I don't like doing that, so, I remove the blade to save the tip. I don't know if doing this makes any difference or not, but, I've owned this saw for over five years now, and I've never had to spend any money on parts or repairs.
Len
It won't hurt your saw if you leave it tensioned, but I usually release the tension when I'm done for the day.
I think what is more important, if you have a cast iron table as on the DeWalt and the newer Delta saws is to wax the table so it won't rust.
I always detention the blade also, the manufacturer of both my old scrollsaw (Delta Q3) and new (Excalibur) recommend this.  I also cover my scrollsaw with a very large garbage bag, meant for wheelie bins.
