2024 Custom Ornament Business Kit - Now Available - SALE 50% Off Through Dec. 2nd ×
FD TC (two way cut) vs. FD UR (Ultra Reverse)?????
oneleggimp
I have looked long and hard at the drawings of both blades and their specs and I can't see any substantive difference.  I know a lot of you folks like the UR blade.  Does anyone know what the real difference between the two blades is and why you should choose one over the other.
Inquiring minds want to know.l
Strange - that's not the way I'm reading the listing on Mike's workshop:
Flying Dutchman - 2-Way Cut Top quality saw blades for wood with alternating
Model Length
inches Width
inches Thickness
inches t.p.i. Reverse
Teeth Drill Bit Size FD-TC No. 2/0 5 0.027 0.008 15 Every 3rd 70 FD-TC No. 1 5 0.030 0.011 15 Every 3rd 68 FD-TC No. 3 5 0.035 0.013 13 Every 3rd 64 FD-TC No. 5 5 0.036 0.015 13 Every 3rd 63 FD-TC No. 7 5 0.043 0.017 10 Every 3rd 56 FD-TC No. 9 5 0.050 0.018 8 Every 3rd
55
Flying Dutchman - Ultra Reverse
Top-grade high-speed fretsaw,  with reverse teeth.
Splinter-free finish on top and bottom surfaces.
"See Testimonial Page
The dent mark is the top of the blade. UltraRev.jpgModel Length
inches Width
inches Thickness
Teeth Drill Bit Size FD-UR No. 1 5 0.029 0.011 15 Every 3rd 68 FD-UR No. 3 5 0.031 0.013 15 Every 3rd 65 FD-UR No. 5 5 0.037 0.015 15 Every 3rd 60 FD-UR No. 7 5 0.043 0.017 12 Every 3rd  56 FD-UR No. 9 5 0.053 0.018 12 Every 3rd  1/16
Both illustrations show the same tooth arrangement: 2 down and 1 up and the individual blade description on both blade styles is the same showing reverse tooth every third tooth so I remain confused.
I have used both rev. and crown saw blades. both by Olson I use the crown  cut blades on thicker stock 3/4 and larger. With olson's blades I don't have to sand the ends and use alcohol I used Olson right out of the container. and they don't rust even over the winter..   other than that there isn't enough difference I get about 1 hour out of each
Model Length
inches Width
inches Thickness
55
inches Width
inches Thickness
Jerry i'm going to swich to the ultra reverse blades now that you brought this to light,Thanks,Ho HJo Ho here go to the "Gross-ery store"
With the Ultra Reverse blades you should only cut with one specific end in the down position. Because, the tooth pattern only goes so far up the blade. Whereas with the Crown tooth type of blades, you can install either end in the up/down position and the blade still cuts the way it's supposed to. And, that is because the tooth pattern is repeated along the length of the blade. So, with the crown tooth blades, you could get twice as much cutting done with one blade supposedly. Of course, that all depends on if you break the blade before you flip it over.
Len
