Have been having trouble with the bottom blade clamp not holding the blade.  Did all the normal things but no help.  Noticed the bottom clamp assembly moving about 1/8" up and down.  The bearings on the top bolts (pencil pointing to) had worn out.  This caused a lot of "jerking" which would make the blade come out of the clamp.  Syco said the new assembly has been made stronger and shouldn't have this trouble again.  The saw runs and sounds like new again.
It's the center boltt that wears out on my dw788's and the bolts even break in half and not fall out.That's the problem with the oriental saws i had,jerking,snatching!
