Made this on just to see if I could do it.After a lot of experimenting with table angles ,size of blade , thickness of wood & direction of cut etc.Then I found out there was a tutorial on it,anyway this is what happened .i seem to have grasped the idea of how to go about these now, hope so anyway,I used a number 2 skip tooth blade !/4" timber An a table angle of about 1 degree.
that a boy.  now you are one the path to a new endeavor. We should be seeing a lot of new creativity coming from you this year. I hope to be right behind you. I am hoping on starting my efforts at inlays again, in a couple of weeks or so, Thanks for your info.
Dick
heppneguy
Outstanding work,Send us the tutorial to copy
