jbrowning Posted December 30, 2015 Report Posted December 30, 2015 So it is a whopping 14 degrees outside so I'm stuck inside thinking. And something just came to mind. When I'm cutting the jigsaw puzzle out with the picture on the front. Will/should I put a clear coat or polyurethane on the back after I cut it out or before I cut it or do I need to worry about it? I will be using Baltic Birch Plywood 1/4". Come on warmer weather. Thanks Jim Quote
Young_Scroller Posted December 30, 2015 Report Posted December 30, 2015 Ive never cut a puzzle before but I would think before because that would make it easier so you didnt have to apply it to a whole bunch of pieces one at a time. I dont know for sure though. jbrowning 1 Quote
dgman Posted December 30, 2015 Report Posted December 30, 2015 I have never finished the back of a jig saw puzzle. jbrowning 1 Quote
amazingkevin Posted December 30, 2015 Report Posted December 30, 2015 I too never have done anything to the back ,but before hand would be better jbrowning 1 Quote
heppnerguy Posted December 30, 2015 Report Posted December 30, 2015 no finish on the back of any for me either Dick heppnerguy jbrowning 1 Quote
oldhudson Posted December 30, 2015 Report Posted December 30, 2015 I've never done a puzzle before but for all my woodworking I generally finish the entire piece, front, back, outside, inside and bottom. I just think it's more professional. Just my 2¢. jbrowning 1 Quote
Phantom Scroller Posted December 30, 2015 Report Posted December 30, 2015 Never coated the back before on my puzzles it's either in a box or on a table so can't see it anyway. Roly. jbrowning 1 Quote
MrsN Posted January 1, 2016 Report Posted January 1, 2016 I usually finish the back of a puzzle with a coat or two of poly/lacquer/acrylic spray, depending on the project. I just like the way it looks and feels. On a related note. If you only finish one side of a piece of wood moisture is absorbed and released differently and it will warp. Baltic birch plywood is considerably more stable than solid wood (and other plywoods) so I don't really think it would warp much but it is often a good idea to finish all sides. jbrowning 1 Quote
jbrowning Posted January 1, 2016 Author Report Posted January 1, 2016 But on the front a picture will be glued to it. Would that act like a finish? Thanks Jim Quote
dgman Posted January 1, 2016 Report Posted January 1, 2016 What Katie said is correct. But puzzle pieces are small and not likely to warp. The bottom line....if you are concerned, finish the back! Quote
