Sparkey Posted January 8, 2016 Report Share Posted January 8, 2016 I noticed a lot of you use 1/8" BB. I have only used 1/4". For those that have used both do you notice a difference in the look of the finished product because of the thickness. I heard from somebody once that he thought 1/4" looked better because it extra thickness gave it a better effect. Quote Link to comment Share on other sites More sharing options...
DonR Posted January 8, 2016 Report Share Posted January 8, 2016 Although I like the look of 1/4 inch, I use mostly 1/8 inch mainly because it fits in a store bought frame better due to the depth. But really, I like 'em both! Don R woodknots 1 Quote Link to comment Share on other sites More sharing options...
Frank Pellow Posted January 8, 2016 Report Share Posted January 8, 2016 I assume that by 1/4 inch, you mean 6 millimetre. I prefer that thickness for the reason you stated, the thickness looks better or, at least, it looks better to me. I build my own frames so DonR's reason for preferring thinner plywood doers not apply to me. tomsteve 1 Quote Link to comment Share on other sites More sharing options...
jerry1939 Posted January 8, 2016 Report Share Posted January 8, 2016 If it is something to be glued on a black backer, I like 3.175 mm (1/8") for the cut piece. That way, the black is only half the distance "back". In my opinion, cutting a 6.35 mm (1/4") doesn't look as nice. jerry Lucky2 1 Quote Link to comment Share on other sites More sharing options...
Ron Johnson Posted January 9, 2016 Report Share Posted January 9, 2016 I use ⅛" Baltic Birch when cutting portraits being I'll stack cut three or four at the same time and I usually frame each with glass in front. For other projects not being framed I'll use ¼" and thicker. tomsteve 1 Quote Link to comment Share on other sites More sharing options...
orangeman Posted January 9, 2016 Report Share Posted January 9, 2016 (edited) I use 1/8" Baltic Birch for my tray type puzzles. But I use 1/4" Baltic Birch for my Christmas card puzzles. Where I live I have only found one source of 5' x 5' 1/8th BB and that is 50 miles away. I've tried to convince a closer source to stock the 1/8" BB to no avail. They say there is no demand. How would they know? They have never carried it! I have noticed no difference in the quality of either. But time to time I have noticed there will be a 1" oval piece that is glued in to one side. That is annoying but usually I can work around that. I have found that in both 1/8 and 1/4. Otherwise the quality is the same. Edited January 9, 2016 by orangeman tomsteve 1 Quote Link to comment Share on other sites More sharing options...
Sparkey Posted January 9, 2016 Author Report Share Posted January 9, 2016 Thanks for the replies. I build my own frames so that is not a problem. I also stack cut three pieces of 1/4" at a time. I guess I will go buy some and give it a try. tomsteve 1 Quote Link to comment Share on other sites More sharing options...
Lucky2 Posted January 9, 2016 Report Share Posted January 9, 2016 I like to use the 1/8"bb, I find the 1/4"bb leaves more shadow on the backer board than I like. Len Quote Link to comment Share on other sites More sharing options...
Phantom Scroller Posted January 9, 2016 Report Share Posted January 9, 2016 The only reason I use 1/8 is to stack cut otherwise I use 1/4 all the time with no glass in bought frames. Roly Quote Link to comment Share on other sites More sharing options...
wbr Posted January 9, 2016 Report Share Posted January 9, 2016 Where I live I have only found one source of 5' x 5' 1/8th BB and that is 50 miles away. I've tried to convince a closer source to stock the 1/8" BB to no avail. They say there is no demand. How would they know? They have never carried it! I have noticed no difference in the quality of either. But time to time I have noticed there will be a 1" oval piece that is glued in to one side. That is annoying but usually I can work around that. I have found that in both 1/8 and 1/4. Otherwise the quality is the same. A lot of it sold is B/BB or BB/BB B is the good side,no plugs,limited pin knots. BB has more knots and a limited number of plugs I get 1/8" stuff from Wurth wood group, B/BB for about $17.50 A 5'X5' sheet. They're over 100 miles away but they deliver in my area twice a week. There's one in Atlanta. orangeman and tomsteve 2 Quote Link to comment Share on other sites More sharing options...
Kepy Posted January 9, 2016 Report Share Posted January 9, 2016 I use both thicknesses depending on what I am doing. If I'm using a backing, I like the 1/8" but for a stand alone, I like the 1/4". I have had it special ordered at both HD and Lowes as well as my local lumber yard. Quote Link to comment Share on other sites More sharing options...
orangeman Posted January 9, 2016 Report Share Posted January 9, 2016 wbr, Thanks for the tip on Wurth Wood products. I will have to check them out! Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted January 10, 2016 Report Share Posted January 10, 2016 I noticed a lot of you use 1/8" BB. I have only used 1/4". For those that have used both do you notice a difference in the look of the finished product because of the thickness. I heard from somebody once that he thought 1/4" looked better because it extra thickness gave it a better effect. I scroll too much to spend time making frames,lol GrampaJim 1 Quote Link to comment Share on other sites More sharing options...
Young_Scroller Posted January 10, 2016 Report Share Posted January 10, 2016 ive only used 1/4 inch because thats what is easily available, I would like to try 1/8 because you could stack more, I dont know if there is a big difference between them, more of a matter of preference Quote Link to comment Share on other sites More sharing options...
heppnerguy Posted January 11, 2016 Report Share Posted January 11, 2016 I use both, but 1/4 inch is way easier to cut. But for some projects, like Christmas ornaments, where the thinner,the better. I always us 1/8 inch. if I am going to use a backer board I will often go to the 1/8 inch because I prefer not to have the thicker depth. I think it looks better that way. Dick heppnerguy Quote Link to comment Share on other sites More sharing options...
