Thanks guys! Couldn't get it out. There's a red reset button in the middle, no place to put a screwdriver. I did tap around on the motor and the area around the breaker and it started working again. Maybe the connection was just stuck open.
I would check the saw out!!!!!!!!!!!!!!!!!!   But don't break the warrenty.
That's a new saw. Is it still under warrenty?
It may be a good idea to disassemble and check motor mounts are tight.
While it's apart, grease bearings because Delta and Dewalt don't grease well.
I have two Deltas, A 40-694 and a 40-690...
Good saws....
PM me if you have any questions..
Edited by LarryEA
Those fuse holders are easy to open....once you know how. Just push in and down on the red piece with your finger and it should pop out into your hand, or at least come out about 1/2 way. To put it back in with a new fuse, just push in and up, and it will return to the pictured position. That little metal tab in the space below the red plastic is the latch, but using screwdrivers and prying on it will destroy it.
Charley
