WOW!  For a learner, you are certainly on the right track.  If I were to make a humble suggestion, it would be that if you look, most designers put their bridges at the bottom of the islands.  In a couple of minutes I will post a new pattern titled;  "Religious Word Art"
I'm sure the other designers will also try to help you.  When designing, deal with frustrations as just a way of life!  :x
jerry
Thanks Jerry, I will keep an eye open for your new pattern post. No problem with frustrations for me. I looked at it and it looked like something could be better just can't figure it out. To me the pattern looks very busy...which isn't good to a photographer.
Jim
Jim, great start.  I like the script font but I would change the positions of the bridges like Jerry suggested. Here's where I would have put the bridges. See the red marks.
I would also have made the white space around the script font larger. That makes the script a little more pronounced. Hope this helps.
Jim
Great job on your first pattern. Learning is a very exciting place to be. Congrats on taking the leap. We are start at the beginning. Other then the the bridges, I would widen the names on the sub letters  a little bit. Great job. Your definitely on you way :)
I have started working on a scroll saw pattern for a friends last name and her kids first names. Here is where I'm at now. Any suggestions/advice would be greatly appreciated.I am using Inkscape and have been watching Travis' classes.
Bonnie%20Aitchison%20Name%20Scroll%202_z
Thank you
Jim
your a quick learner!
