I am so new the empty box is still in the garage, but I already know this starter saw is going to have a limited useful life span. So I am reading soaking up what I can, hoping osmosis (one of the few words I remember from HS science) will work.
Anyway I ran across a comment somewhere on the net, sorry I did not keep the link, there was a discussion on the ex-21 vs the 788 and one said that the ex-21 would mean you cut slower than with the 788.
Since the speed control range is similar, anyone have any idea what they meant?
What Don said.  I have had a DW788 and now have an Excalibur.  Both great saws, I like the Ex the best.  I really do not remember the DW being faster, so it is probably not much, or I have scrolled long enough now on the Ex that I can make up the difference.
I've used both and own the 788. If you think the 788 is too aggressive why not just slow it down? That really sounds like a non issue to me. I do think the EX-21 is a more refined and smoother saw. If you can afford it, go for the EX-21. But you won't be unhappy with the 788. I thought about buying the EX-21, just couldn't justify the difference as I do many other crafts. If it were my only or main craft I probably would buy one.
I read somewhere that the motor on the ex can be turned one way or another for aggressive cutting or non aggressive cutting.
I have both saws, and am happy with both.  I did adjust the EX for minimal blade travel, but in actual use on the 788, I don't notice much of a difference.  When cutting thick wood on the Hegner, which has virtually no travel, I do notice that it takes more effort and prefer the other two saws for that type of cutting.  I think you would be happy with either saw.  They both have their strong points.
Edited by hotshot
