LarryEA Posted January 26, 2016 Report Posted January 26, 2016 Hav e you scraped wood instead of sand? “How to Use a Cabinet Scraper | Woodworking†— I did not know this until yesterday. Scrape to smooth wood surface. I might try this. Quote
JohnR48 Posted January 26, 2016 Report Posted January 26, 2016 The hardest part is getting the hook set properly, but once you master that you will get a much better finish than you can with sandpaper. A heavy scraper is also very good for removing glue squeeze out. LarryEA 1 Quote
Wilson142 Posted January 26, 2016 Report Posted January 26, 2016 I've used scrappers for a long time. Not sure they would work well for scroll saw projects, but maybe used gently. Once you learn to create the correct burr, scrapers work great, Both with and across the grain. I've also used pumice, rotten stone and even cigar ashes to perfect a finish. It's quiet and very therapeutic. It was in my "French Polish" period. lol LarryEA 1 Quote
oldhudson Posted January 26, 2016 Report Posted January 26, 2016 I use a cabinet scrapper quite often, but never on a scroll saw project. LarryEA 1 Quote
bandaideman Posted January 26, 2016 Report Posted January 26, 2016 I did use scaper for a time. But it is important to get the burr right and learning way to scrape. It does give a good finish. I used to scape the wood before i did the scroll sawing and the finish stayed pretty well. LarryEA 1 Quote
heppnerguy Posted January 27, 2016 Report Posted January 27, 2016 I am not even sure what a cabinet scraper is. I guess I will need to Google it Dick heppnerguy Quote
Rob Posted January 27, 2016 Report Posted January 27, 2016 They do work well but over enthusiastic use can burn your thumbs! Rob LarryEA 1 Quote
amazingkevin Posted January 27, 2016 Report Posted January 27, 2016 Hav e you scraped wood instead of sand? “How to Use a Cabinet Scraper | Woodworking†— I did not know this until yesterday. Scrape to smooth wood surface. I might try this. Depending on what i need to get done.Sometimes a razor blade will work shaving off minuscule top coats other time a paint scraper is needed! Quote
