I saw this pattern in Wooden Teddy Bear, but I like to give credit to the designer.  I called them and they were very helpful giving the name of the designer, Mark Weyers.  I used 1/4" Baltic Birch plywood and backed with a medium brown mat board.  I used FD New Spiral #1 for most cuts and FDUR #1 for the straight cuts.  The size is 10" x 12" and framed at our shop, ArtCrafters.  Comments welcome.
This is a rare site to see of an archer done by scroll saw.Probably only the second one I've run across in 11 years of searching the net for patterns.Quite a bit of skill used to go from spiral to flat blade and not mess up forgetting which blade your using at the time.Well done friend!
