amazingkevin Posted February 19, 2016 Author Report Posted February 19, 2016 Mind that wrist Kevin don't want you back down the doctors. Roly Wrist is doing good Roly,The 33 days of exercise fixed it up real good! Phantom Scroller 1 Quote
amazingkevin Posted February 19, 2016 Author Report Posted February 19, 2016 Looking good Kevin, take your time and get it just the way you want it. You'll be back to putting out beautiful work in no time! Thanks Joshua,I can't wait! Quote
amazingkevin Posted February 19, 2016 Author Report Posted February 19, 2016 Wow, with 16' height you could put a second floor in there! Only one light bulb? How are you going to replace it? Maybe it would be easier to put a few 2X4s across at an 8' or 10' level and fasten some lights to them. Are there outlets on the walls, or do you have to install them too? A few days of organizing should get you back to woodworking. Congratulations on the new shop space. It will be great, once you get everything organized and off the floor. Charley A pole light bulb changer worked like a charm,but i do need to run lots of outlets for all the machines. Quote
amazingkevin Posted February 19, 2016 Author Report Posted February 19, 2016 Wow, with 16' height you could put a second floor in there! Only one light bulb? How are you going to replace it? Maybe it would be easier to put a few 2X4s across at an 8' or 10' level and fasten some lights to them. Are there outlets on the walls, or do you have to install them too? A few days of organizing should get you back to woodworking. Congratulations on the new shop space. It will be great, once you get everything organized and off the floor. Charley 8 outlets on one side will do the trick! Quote
