romka555 Posted December 21, 2009 Report Posted December 21, 2009 I am new to scroll sow, and as i start, i do really have no idea how to do thin line cutting. I have pin ended blades. Thank you Quote
Kepy Posted December 21, 2009 Report Posted December 21, 2009 It is very difficult to do thin lines with pinned blades. The best you can do is drill the smallest hole possible then feather out from the hole to make it disappear. You can usually find a spot on the line where it is not so noticeable. Quote
Travis Posted December 21, 2009 Report Posted December 21, 2009 Will your scroll saw take pinless blades? Most scrolling is done with with pinless blades. It is much easier to thread the blade through pilot holes this way. With veining and line cutting especially, you're pretty limited pinned blades. I've seen some people remove the top pin, thread it through the pilot hole, then re-insert the pin (or use a small nail). This is very time consuming and, depending on the brand of blade, it may not be possible. If you can use pinless blades, I strongly recommend that. You can find some quality blades from Mike's Workshop. I'd buy his sampler pack to get a feel for different types of blades. These are all pinless blades and will produce really great results for you and pretty cheap (compared to the stuff you find at the hardware store). Welcome to the hobby. You'll have a great time with it. If you have any questions, please don't hesitate to ask. There are a lot of friendly and knowledgeable folks here. Quote
romka555 Posted December 22, 2009 Author Report Posted December 22, 2009 Thank you. I do have a holders for the pinless blades i will try to do as you advize. Thank you once again. Quote
Trimax Posted December 22, 2009 Report Posted December 22, 2009 while ou ordering from mike also he carries drill bits that your going to want to get cant really find them cheaper that I've found 65-68 are what i usually get buy a dozen you wont regreat it Quote
