As to whether I can get this back together or not!  I just could not take the vibration anymore, so being stubborn I decided to try to fix it myself.  I order a new leakage assembly for the Ex.  It came today so heck dive in.  The instructions were typical of these things.  They are for an Excalibur of about three generations ago.  But looking/reading the instruction and my owners manual parts pictures I was able to get it apart and the old linkage out.  I'm hung up now because I know nothing about grease, and the main bearing on the new linkage is not greased.  This is what my saw now looks like, my scrolling days may be over, and this is the only type of grease I have on hand.  Anyone able to recommend a grease or is this good enough?  Think I can get this thing back together???
Lucas is good grease; the videos on the DeWalt recommend a full synthetic though.  Probably is supposed to stand up better!
Any decent grease will beat none!  You just may have to redo sooner.
Be careful to not let sawdust or any other contaminant into the grease and you will have enough for several "lube -jobs"!
Is the main bearing on the new linkage a sealed bearing? If it is then it shouldn't require greasing. I would say the grease you show Paul will be okay. For additional assurance contact a machinist or mechanic. It's odd that you have to replace the linkage when usually it's a simple adjustment when it comes to vibration. I'm betting you'll have this machine running like new again. I would contact Ray at Seyco if additional help is required. All the best Paul.
Paul, I agree with Ron, if it's a sealed bearing, then it doesn't require any grease. Applying grease to a sealed bearing will not do the bearing any good, the bearing is sealed to stop contaminants out. How old is your saw, it looks like the anniversary special they put out?
Len
Thanks for the input.  The main bearing is not a sealed bearing (see picture).   My saw is not quite 2 years old.  Fact when I got the owners manual out I noticed it still has a couple months under warranty.  Guess I voided that by taking it apart, but where I live there is no maintenance or warranty type outfits.  So I would probably have had to do it myself anyway.  I tried all the adjustments I could find on the internet.  Nothing seemed to improve it much.  This may not fix it either, but wanted to try.
I'm thinking that if it does, I will try to get new bearing for the old drive and replace them.  Have a backup.
Paul,
   I have some of the synthetic grease too. They sell it at Napa. It is supposed to be the best grease of all. but I trust LarryEA and if he says the grease is OK then I would use it. Your call. If you need any help,, from there, let me  know..
Dick
heppnerguy
I bet you found the problem!
Well, I got it back up and running, but like everything else I ended up with a left over part!  See picture, the white object.  I think it just goes in the upper arm cover to maybe make sure the wires stay in place.  Although, I don't see where the wires would go.  It runs, it is quieter, and feels like it is running smoother.  Need to work with it a while and see if it remains so.
Thanks for the support, help and advice.  I love doing something like this.  It really was not hard.  The reason I dove into it, I have had a problem with my table saw for some time that I just kept ignoring, thinking it was my imagination.  But the blade seemed to move to the right every time I lowered it and raised it up.  When it came up I would have to run it to shave a little of my zero clearance.  Finally decided I had to look into it.  All that waiting, and it only took a couple house to remove the table top, find the problem, fix it and put it back together.  Wasn't worth stewing over.  So got a problem with the scroll saw, try to fix it.  Don't keep putting it off.
Edited by Scrappile
