hello all,
I have a pattern that says bore a hole 2-3/8 for clock insert so what is the rule of thumb when it comes to buying a clock for it ? do you go a 1/4 smaller for the clock size or what? Some patterns tell what size of clock to buy. thanks And have a Merry Christmas
hello all,
As mentioned there is no set rule. Always check the clock insert. The company you buy from will always tell you the hole needed.
