What blades is the best to work with? I start work with really small size and i do like it, but it is all that i've got for now. i never worked with other blades. I mean the size of the blades. Please give me some advice. thank You
It really depends on what you're cutting. Small blades tend to wander a bit, while larger blades do arches and straight lines better. Small blades turn tight corners much better as well. The thicker the wood, you'll want a larger blade. But here are my go-to blades:
#3 for most cutting up to 3/4" that require sharp corners.
#5 for 3/4" wood or when long straight lines or gentle curves are needed.
#9 for hard and thick woods.
#1 or #3 spiral blades only for portrait style cuttings that have a lot of organic lines (curvy).
I use Flying Dutchman from Mike's Workshop. So if I was to buy 12 dozen blades, here's my shopping list:
    [*:2bn8qnz5]#3 Scroll Reverse (FD-SR No. 3) - 6dz
    [*:2bn8qnz5]#5 Scroll Reverse (FD-SR No. 5) - 2dz
    [*:2bn8qnz5]#9 Scroll Reverse (FD-SR No. 9) - 1dz
    [*:2bn8qnz5]#3 Spiral Flat/End Scrollsaw Blades (FD-SP-FE No. 3)- 3dz
Thank You so much. The thing is that, i live in India for the last 9 years and here no one knows about scroll saw, so there is nothing in the market for this work. I got a scroll saw from USA and i do really enjoying it. thank You once again for your help guys. And MERRY CHRISTMAS!!!!!!
