tonylumps Posted March 1, 2016 Report Posted March 1, 2016 I just read the owners manual about using pinned blades on my 18V and no mention of it.Has anyone tried a pinned blade on there saw.I just tried it and it seems to work. Quote
stoney Posted March 1, 2016 Report Posted March 1, 2016 Boy! I have never tried it. I'm wondering why you would. Do you have some pinned blades you are trying to use up? I would think in order to clamp them you would have to have the pin outside the clamping surface which changes the normal distance between the upper and lower arms. I would think that would cause a forward and backward movement of the blade. Quote
tonylumps Posted March 1, 2016 Author Report Posted March 1, 2016 The reason why I am asking is I just ordered sanding belts for a scroll saw from Wooden Teddy Bear.I ordered Pin type and it mention that I could use them on the Hegner.but I also have a Porter Cable that I could use them on. So I took the clamps off of the hegner and mounted a pin blade where the clamps mount.I adjusted the tension a little and the the pin blade works fine.There is a very very little fore and aft movement And I do have a lot of pin blades But that was not the reason Quote
