On 6/22/2020 at 3:20 PM, octoolguy said:
Hey Montserrat, where are you located in Tennessee? We are getting ready to relocate to your fine state in or around the Knoxville area. Maybe we'll be neighbors.
Hey Ray, I saw your post with question for Montserrat - and wanted to tell you she has her location on the members map.  If you go to her profile page, and click on the map there you can see she is more in middle TN area - south of Nashville - close to Murfreesboro, TN so about 4 hours are so from Knoxville area based on looking at that map location.
I always forget to look at the members map. Thanks.
  • 5 months later...
On 12/10/2020 at 4:52 PM, Carlxxxx said:
I have a Excalibur ex21 just bought . I works good but at full speed vibrates but at 85 % power no vibration. Should I tighten all Allen  head bolt up real tight or leave them the way from factory?
Leave them as they are. It's possible to over tighten. There are many other things that can cause vibration. Is it firmly mounted? How old is it? It might need general tear down for inspection and lubrication. Where was it made? If Chinese, that may be part of the problem. Canada & Taiwan were the best saws. The biggest problem is dry bearing/sleeves. We really need more info and maybe some pics. I've got two EX's that don't vibrate.
  • 3 months later...
On 3/18/2021 at 9:49 PM, Ray Rivard said:
The blade tightening thumb screw on my Excalibur just stripped out.  Has anyone ever repaired this with a Heli-coil, M-6 thread, I believe. Seems like it might be a less expensive fix than whole mounting unit with a Pegus block..
Maybe so but if it doesn't work out, it's money down the drain. Bite the bullet and buy the Pegas clamp set. They are so much better. Less vibration because less weight and the flip lever is better. Everything about them is better than the original design. You won't be disappointed except for when your credit card bill comes in. After that, smooth sailing.
On 6/17/2020 at 12:17 PM, NC Scroller said:
For anyone else here is what I did to resolve the issue.  This rubber band has been in place for well over a year and the knob has not moved a bit.
Simple-Easy- No Cost fix = Priceless
This worked for a long time. I recently had to replace the rubber band and am now back in business!
