I'm starting my first large pattern tomorrow.  It'll be about 20" across and about 15" high.  Using a spiral blade for most of it, but might use the flat blade for a few long, straight spots.  Any suggestions or tips for large patterns?
Using a dewalt 788 saw for it.
Spray glue a piece of thin wood on he table to make your cutting table wider than your project to help you out.
Kevin has a good thought. The only problem then is the depth of the throat of your saw. I try to place me entry holes in a fashion so that I can make my cuts using a straight blade. Not a huge fan of spirals but use them when no other choice is available.
That's a goof idea, John. When I have a large pattern to cut, I add a wing on one side of my 788. I do use spirals the majority of the time, even on small works. I like working with them as I can turn the wood if I want to. Just stop & turn the piece without continuous movement. Good Luck
