breadstick Posted March 14, 2016 Report Posted March 14, 2016 I've just started doing portraits, but this should apply to most things we cut. What size do you make your backers if you sandwich a piece of felt between them and the cut piece? Ideally I'd like it to all be one size, but if I use a plywood backer (probably 1/8") the side you can see would be different than the main piece. Do you normally make the backer a bit smaller to hide it if you can? amazingkevin 1 Quote
Gordster Posted March 14, 2016 Report Posted March 14, 2016 The majority of portraits I do, I put them under glass in frames. I just use posterboard as backer and cut it the same as the glass. At one time I used felt, but it gets bunched up in the frame. Quote
edward Posted March 14, 2016 Report Posted March 14, 2016 I use felt all the time for my portraits, I glue it to the back of the portrait with spray glue, then trim, never had a problem. edward Quote
Denny Knappen Posted March 14, 2016 Report Posted March 14, 2016 Owning a framing shop has another advantage. We always have small pieces of mat board which I use as the backer. Fit in a frame and no one notices. Quote
Scrappile Posted March 14, 2016 Report Posted March 14, 2016 I use posterboard. Spray the back of the picture and lay the posterboard on it. Cut the posterboard the size of the wood the picture is scrolled in. Quote
Ron Johnson Posted March 14, 2016 Report Posted March 14, 2016 I use foam being I like the backing to be as rich and dark as possible and cut to size of frame glass. If need be I'll tack glue a couple spots on back of portrait to adhere backing in place. If I need to replace the backing at a later date I then have no issues. Quote
jerry1939 Posted March 14, 2016 Report Posted March 14, 2016 I don't use felt, so perhaps this may or may no help. I only glue the cut piece directly to a painted backer. First I make all the inside cuts. Glue that to the painted backer. Lastly, I cut the perimeter, which gives a perfect match. Hope this gives you ideas Friend. jerry amazingkevin and Dave Monk 2 Quote
bandaideman Posted March 14, 2016 Report Posted March 14, 2016 I have done many of the same things. I have used construction paper cut to size, poster board, felt, plywood painted etc. I usually did put them in a frame with or without glass and not glueing but then the back of the frame would not fit back on. I have decided I like it without the glass whcih helps with the fit of the back. Portraits don'e seem to sell well around here so I don't do them much any more. The issue I had with felt is little particles stick to it easily and dust or airborn things so don't use that anymore. I have had better luck selling with use of the bass wood rounds with bark on and the portrait centered. works good with animals but people are fine also. I do glue a 1/8 or 1/16 in backer on it to hide the back. Just some of my thoughts. Like most things just comes down to personal preference and what customers or friends like. Quote
WayneMahler Posted March 14, 2016 Report Posted March 14, 2016 I attach felt to the backer board then glue the art to it. Once in the frame everything stays safe and put. Quote
amazingkevin Posted March 15, 2016 Report Posted March 15, 2016 I'm poor and use construction paper for my backers when needed .they come in a rainbow of colors at the dollar store 2 for a dollar I've just started doing portraits, but this should apply to most things we cut. What size do you make your backers if you sandwich a piece of felt between them and the cut piece? Ideally I'd like it to all be one size, but if I use a plywood backer (probably 1/8") the side you can see would be different than the main piece. Do you normally make the backer a bit smaller to hide it if you can? Quote
NC Scroller Posted March 15, 2016 Report Posted March 15, 2016 I use mat board or painted 1/8" plywood for my framed portraits. 90% of the time my background is black. Quote
Bill WIlson Posted March 15, 2016 Report Posted March 15, 2016 Like most others replying in this thread, I prefer to use frames for portraits. I think they look more finished that way. I make my own, so they are custom cut to fit whatever size I make the portrait. I don't think I would use felt as a backer, myself. I would be afraid of it being more of a dust magnet, over time. I use mat board or colored ply. I don't paint or stain the ply anymore, because I've had it cause some issues with glue adhesion. I've recently been experimenting with fabric dye and so far, I like it a lot. Quick and easy to apply, gives a nice rich color and doesn't seem to interfere with the glue. Quote
breadstick Posted March 15, 2016 Author Report Posted March 15, 2016 Thanks, everyone. I bought some felt this weekend and might give it a shot with some smaller pieces later, but I got some black foam board that works well and looks great. I love wood grain, so some projects get a coat of ebony stain on thin birch plywood with no sealer. Looks great, but more cost and weight. Quote
Denny Knappen Posted March 15, 2016 Report Posted March 15, 2016 I am sure most of you live near a custom frame shop. We have mat board fall outs which could be free or little cost. Check it out. Quote
Lucky2 Posted March 16, 2016 Report Posted March 16, 2016 Nathan, I use 1/8" birch plywood, or 1/8" masonite. My backers are always the same size as the portrait cutting, and are usually painted black. Every so often, I'll need the backer to be the frame. When this happens, I place a small washer up against the side of the cutting which is sitting on paper. Then, I insert a pen or pencil in the hole in the washer and trace around the exterior of the cutting. Len Quote
JimErn Posted March 16, 2016 Report Posted March 16, 2016 Nathan, I use 1/8" birch plywood, or 1/8" masonite. My backers are always the same size as the portrait cutting, and are usually painted black. Every so often, I'll need the backer to be the frame. When this happens, I place a small washer up against the side of the cutting which is sitting on paper. Then, I insert a pen or pencil in the hole in the washer and trace around the exterior of the cutting. Len Thanks for that, a simple elegant solution Quote
NC Scroller Posted March 16, 2016 Report Posted March 16, 2016 Nathan, I use 1/8" birch plywood, or 1/8" masonite. My backers are always the same size as the portrait cutting, and are usually painted black. Every so often, I'll need the backer to be the frame. When this happens, I place a small washer up against the side of the cutting which is sitting on paper. Then, I insert a pen or pencil in the hole in the washer and trace around the exterior of the cutting.Len I have a little bag of washers in various sizes just for this purpose. Quote
