A Couple Of Firsts
woodduck
This is the first project on my new EX21 & the first project using spiral blades .Thanks to Neptune for this image.I know it is not perfect but I am quite pleased as to how it turned out.It is cut from Marine Ply & I used 3/0 Spirals. Now to work out what finish to use & frame it Cheers Peter
Peter, it looks perfect to me, how did you like using the new saw?
Len
Worked beautifully Len only problem I have is the spiral blades bending on the lower blade holder I have tried all the tips I have found but still does it,Think I went through about 10 blades on this one.any clues?
Peter, I would suggest that you remove the bottom clamp screw, on the end of that screw there is a small swivel tip. This tip is supposed to set up against the blade, so that when the clamp screw is tightened, the tip stops the screw from bending/twisting the blade. Try rotating that tip with your fingers, if it rotates, fine. But if it doesn't rotate, you'll have to loosen it up. I have used a very small bit of Never-Seize on the tips of my saw, I did that as soon as I bought the saw. The only other thing I can think of that might be causing your blades to break, is that they are spiral blades and I hate them.
Len
Len
Thanks for the input Len but I have already tried this they were very hard to turn so i cleaned them up & lubricated them so they should be fine now.
your a natural born spiral user now .Water over the dam done deal!Outstanding job you did here ,Couldn't be better! :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
