... I got the pattern.  I had some poplar in the raw for compound cutting.  Used the bandsaw to cut it into pieces the right size for birdhouses.  But no matter what I tried, I could not get the pattern to adhere to the wood.  I ended up double-wrapping with packing tape, but it would always slightly slide when cutting the second side.
Either way.  Here are the first six - freshly oiled.  Bought the eye-hooks already.  They are so much fun.
Also, Denny, how do you get the birds onto the perch?  I ended up drilling them in the bottom to fit the perch. post-28761-0-91153600-1458516111_thumb.jpg
Edited by Montserrat
... I got the pattern.  I had some poplar in the raw for compound cutting.  Used the bandsaw to cut it into pieces the right size for birdhouses.  But no matter what I tried, I could get the pattern to adhere to the wood.  I ended up double-wrapping with packing tape, but it would always slightly slide when cutting the second side.
Also, Denny, how do get the birds onto the perch?  I ended up drilling them in the bottom to fit the perch. attachicon.gif1170714_10208037503166745_1689390591628738895_n.jpg
Please please some one some where send me mini bird houses for me to have at.These beauties have tantalized me long enough.Montserrat i wish we could team up and mass produce these 1 fold.your very good at what you do and i would love a teacher like you pupil in training!
Wow nice going on the Miniature Birdhouses.  As for attaching the pattern to the blank, I copy the patterns to contact paper, then cover with packing tape.  After the first cut keep the blank in stock and wrap again with packing tape.
I also drill a hole in the base of the bird blank to fit the dowel.  For the dowels, I use wood skewers.
Yes Kev just purchased the plans for the birdhouses myself ,you can get them from Diana Thompson"s site www.scrollsawinspirations.com
I have made lot's of mini birdhouses, everybody loved them.
I used 1/8 dowel for the perch to hold the bird and also I used lint from the dryer to put in the hole with a little bit of dried grass, just put a little bit of glue in the
hole and then put the lint and grass in.
Attached are some finish products and some are still in the unfinish state.
