stack cut 1/8" plywood?
breadstick
No, 1/8" ply is not to thin for spirals when stack cutting 2 or more at a time. Now this is using Baltic Birch ply. You want to make sure that the ply you are going to purchase is at least cabinet grade and with little or no voids. Does the sawmill have different types of ply such as oak, cherry, poplar, etc? Some times oak will splinter at the wrong place of the cut and stick out like a sore thumb!
Erv
Edited by redwine
I'm heading to a new sawmill tomorrow and will definitely be getting some new plywood.  I've been using 1/4" because it's what I can get closest.  I'm at least getting 1/8" for backers, but I thought it'd be easier to stack cut 1/8" three at a time, but is it be too thin to use spirals?
Show us what you purchased,show us your shop lets have a peek at what your latest project is!
Is it a sawmill you will be going to, or is it a plywood mill? There is a difference, sawmills cut lumber and plywood mills make plywood. If it is a plywood mill, are you sure they lay-up 1/8" plywood. The one I worked at didn't, they just couldn't turn the stock thin enough to go through the dryer.
Len
It's a sawmill.  Checking it out tomorrow when my sister-in-law goes back home.  They only sell hardwood 4/4" an thicker, but they will saw one down for me if I buy one, so I'll essentially get three boards for the price of one (plus the $15 fee saw fee).
It sounds to me like you are going to end up with 3 pieces of hardwood 1/8" thick by the sawmill re-sawing 4/4" boards.   Are they going to cut the pieces over size an then plane down to 1/8" or are they going to end up rough sawn?  To end up with 3 pieces that can be planed to 1/8" out of a 4/4" board they would have to be using a band saw mill.
Edited by stoney
Ok now we are getting some place.   You are buying plywood and hardwood boards.   I'm glad we got that cleared up.   I sometimes resaw boards up to 6" wide on my tablesaw and then run them through my planer to the desired thickness.
Edited by stoney
