Compound cuts
edward
Hi Friend.
IF it is just the thumb screw causing the problem, one suggestion would be to take it to a hardware store. Use a nut to determine the diameter and the number of threads per inch. Using that same nut as a guide, find a cap screw that fits it. Use the cap screw as a temporary "fix" while doing your current project.
Hope this helps.
jerry
the problem that i see with Jerry's fix, is the thumb screw has an end that pivots and helps keep the thumb screw aligned with the blade as it travels up and down. I keeps pressure off the blade, or something like that, (not sure how to explain it ). I am not sure how changing the thumbscrew would effect the cutting or the blade. Others understand this way better than I do but I thought i would throw that out and see what other comments come up
Dick
heppnerguy
Edward, I think all you need to do, is to use thinner stock. Try either 1&1/4"or 1&1/8" stock, you don't need the piece of wood to be much larger than the pattern. If using smaller wood doesn't solve the problem, then just minimize the pattern so it fits the piece of wood.
Len
Hi Edward, I think I can help you out.  Firstly I checked my Dewalt and with my thumb screw tightened it is horizontal to the table.  If the set screw opposite your thumb screw is off by a 1/4 turn it will point the long end down interfering with your cut.  Try backing off the set screw a little so that your thumb screw can tighten horizontally.  I noticed the set screw wasn't fitting properly when I had to  purchase a new blade holder.  As long as it doesn't damage your blades you should be good to go.  By the way my saw measures  2 -1/8" from table top to the bottom of the blade holder at its lowest point. ( just in case this means something as well ).
Terry
