Very cute! You are tempting me to try some of this compound cutting. dave
Dave ,Dabble in all the various ways a scroll saw can be used.It really comes in handy having knowledge when problems come up and you have more ways of turning firewood into something way better than it was going to be just from having experience in doing things differently!
I recently test cut this for Sue Mey.  I modified the original pattern by adding the chick.  The chick is actually the same as the larger bird but reduced by 50%.  Thanks for looking and comments welcome.
Smart thinking! i love modified projects. :) :) :D :D :D;) ;) ;):thumbs: :thumbs:
That looks super, like the birds you added and putting the whole thing on a stand is a wonderful idea.
jim
penquin
Jim, the base and large bird are actually part of Sue's design. I just added the chick.
Edited by NC Scroller
Very nice and neat work!
What kind of blade you used? It demanded whether such smooth surface the additional sanding?
I cut the house with a Olson #7 PGT double tooth blade. A #9 might have been better but I did not have any. I used the same #7 to cut the birds. Sanding was minimal.
Looks good Scott, how do you like being a test cutter? How often are you called upon to do a test cut, can you refuse if it's not something you would enjoy cutting?
Len
Len, a month or so a go Sue posted on Facebook if anyone wanted to test cut a pattern. It was a fret pattern and many replied yes. I am not sure how she picked me. All I have test cut for her have been compounds. And yes I have the option to decline (and I have) if I don't like the pattern or don't have the time. I know she has others doing test cutting but not sure who, where or how many.
Wowed, here.  I bought the pattern and tried my hand at it - not an easy feat to get to your results.  Will see where I am at after gluing, but it will need some adjustment.
Montserrat let me know if I can help. Here are a few suggestions to any one attempting these or other compound cut projects.
- Choose a tight grained moderately soft wood such as basswood, alder, poplar, soft maple.
- Put clear packing tape on all 4 sides of the block.
- Change blades like some else is paying for them. I think I used 3 blades to cut the 4 parts of the house.
- I used #7 Olson PGT blades to make mine. #9's would have been better but I did not have any.
- Max out the tension on your saw and max out the speed. Then slow your cut rate way way down.
