Alphonse Mucha was a famous painter of the Czech in the early 20th century. Most of his works were combined in small series. In particular, there are several series "Seasons", consisting of "Winter", "Spring", "Summer", "Autumn". This is one of them.
It was my  first puzzle, created at the end of 2012. I remember it with a smile. Then I took the first steps and tried plywood taste. As I remember, for sticking pictures of calendar, I used white glue and paper too quickly adheres and covered with bubbles. I had to tear it very quickly, to wet with water and apply again more successfully. After that I bought a spray glue. Since it is fewer errors.
Here I used a horrible construction plywood that had a long time to sand. Later, I found a good smooth plywood for subsequent work.
Dimensions 52 * 22cm (20.8 * 8.8), 369 parts.
Your puzzle's are a treat to see !I'd love to try putting one together with fancy pieces you've designed.A real work of art! :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
That is beautiful.  I am a big fan of Mucha and all his work.  Have even cut some of his works in fret cuttings.  I have been lucky enough to have a couple of pattern designers create patterns for me of his work.
The art he created is wonderful and he was truely one of the greats of his time.
jim
penquin
Many thanks!
As I said, it was my very first puzzle. I gave it to my sister and showed pictures on a Russian forum of fans of puzzles. It brought me an order to the next puzzle, etc.
Edited by leshko
