Most the pictures I have cut are stacked in a box sitting on a deck.   I have never gotten to the framing part of the process.  Well I have made a few frames, nothing fancy, but it is not something I enjoy.  The reason, I just don't know much about it.  I'd like to get busy in this area.
I have been looking at mat cutters because I'd like to put matting around some of the pieces.  For my little operation I can't afford to buy a professional cutter, I'm curious if one of the little cutter does a decent job and what other tools does on need for this?
For $82 you can get the cutter and the rest of what you need at WalMart!
  • Features include a 32-inch cutting capacity board, fixed guardrail, mat guide for border widths from 3/4 to 4-1/4"
  • This Logan mat cutter works with standard thickness mat board only (4ply/1.4mm)
  • This package contains one cutting board, mat guide, push-style bevel cutter, straight cut knife, instructional DVD and five blades
Before we bought the custom frame shop, I used the little hand held cutter.  It works, but not easy.  Check with a custom frame shop.  We have what we call fallouts.  They may be willing to cut a mat few a few dollars.  I do all the time.
the things i've bought and never used ,I'm sure i have these too but where ,I have cutting boards with the big knife with a handle on but it doesnt cut good .I would say it will get you thru a few jobs !
No Kevin, that type of cutting board will not do what Paul wants. He needs something that'll do interior cuts, as well as exterior cuts. The one you mentioned would do the exterior cuts to a certain size, but it won't do the interior cuts.
Len
That little hand held cutter looks like it would be hard to use. I also had trouble getting the corners of the frame to look good. I was lucky to be able to buy a used joiner from work when they went out of business. You can find some for a decent price on the web.
BTW...This is where I get my mat board. It comes in 32" x 40" sheets. There is one of their retail stores in Raleigh, NC which is about 90 minutes from me. When I go I stock up.  They do have other retail stores around the country.
http://search.jerrysartarama.com/search?keywords=mat+board
Jerry's is a good source.  Don't buy the expensive acid free mat boards.  There is acid in wood.
Thanks guy, I really appreciate the info.  I just spent about 20 minutes looking around Jerry's.  Sooo much to learn.
My the tool in my picture is an underpinner. It drives v-nails in the corners of the frame to hold it all together.
V-nails are a great fastener for securing the miter joints on picture frames.   They make a variety of tools for driving them.   V-nails can be installed with something as simple as needle nose pliers and a hammer up to an installation tool costing hundreds of dollars.
