hardwood breakage
amazingkevin
Doing these intersecting word art plaques caused me a lot of problems from breakage of thin letters,The boards them selfs even split .I think they are teak or something harder .I used a #9 scroll reverse as the wood cut so slow.Good thing i just re uped on CA glue with spray accelerator.Saved lots of time putting pieces back as the break out All three of the "lord liveth nby three different pattern makers are cut  now .i still have two costa rica limon to do yet .talkative warehouse people hindered my scrolling for hours again .I 'd like to scroll before it gets dark as the bugs start to come inside with the doors open.these hard wood plaques look so much nicer than plywood and with out a finish on the yet.thank you pattern makers.post-1607-0-53121500-1459388741_thumb.jpgpost-1607-0-72943200-1459388758_thumb.jpgpost-1607-0-14344300-1459388780_thumb.jpgpost-1607-0-72814000-1459388843_thumb.jpg i added this icture after i sprayed clear on itpost-1607-0-24478200-1459473485_thumb.jpg
Edited by amazingkevin
Kevin,
I rarely do intersecting word art, but when I do, I put a sacrifice board on both the top and bottom. I consider it cheap insurance.
Also, this was brought before. I never stack cut anything, so the top & bottom pieces are thrown away. I have this thing about never making 2 things alike. Just another of my weird eccentricities.
jerry
Kevin,
jerry
Thanks Jerry ,One of my eccentricities is to do scroll projects all in one piece if i can.
I you need to use a #9 blade to do your cutting, then if it were me, i would just use a different wood and a smaller blade when I was making these signs. I have never had this problem when cutting these projects and I cut quite a few of them. Good luck, Kevin.. Personally, I would not glue a broken board as you do, because I think it takes too much away from all your efforts.  Just my oppinion
Dick
heppnerguy
Dick
heppnerguy
The wood was 3/4" hard and cut slow with the #9 blade,i'm sure a smaller blade would have helped but i don't have time to lay with it.Doesn't look bad glued and sanded now ,Thanks Dick@ ;) ;) ;) ;) ;) ;) ;)
Looking at the pictures it looks to me as if the break is straight across the board and appears like it might have broken along a poorly made glue joint.  Just a thought I know you have said in the past you use a lot of reclaimed wood.
Yes yes yes, All used wood .I think your  right about it being glued together!G :cool: :cool: D eyes! ;) ;) ;) ;) ;) ;) ;)
