wondered if any one had issue wth blade slippage. I have scrolled for about 20 years and am on mysecond dewalt. Ihad done fine until the blade was coming out when scrolling as happens fro time to tme and did te usual things helped but continued. thought I would replace the thumb screws and set screw. Did that todayand if anything it was more of an issue. I only then noted the thumb screw was wabbally like the inside threads were striped a little and may not hold. So contacted local dewalt repair and will see about trying the new thumb screws in a new blade holder there. repair said it would be fine and he would check some front bearings to see f they may be part of issue free of charge justwodered if others had experience wit it.
It sounds to me like the threads on the piece where the thumb screw goes into, needs to be replaced. Not a big deal to do. Maybe you could take that part off your first saw, if you still have it and see if that cures your ills. Just a thought. If you are using something to help you to tighten your thumb screw, like the piece that Steve Good sells the pattern for, I have seen several posts saying NOT to use them as they put too much tension on the thread, causing them to strip
Dick
heppnerguy
I switched the top and bottom thumb screws and that fixed that once.
If you replaced the thumb screw and set screw and still slipping, then you have either cracked the blade holder or stripped the female threads. You will have to replace the blade holder.
When I use FD blades I have to cleanthe blades real well and use sandpaper on them to keep them from slipping, no problems with Olson's.
I also have a DW 788.
Edited by ike
