hbeery10 Posted April 29, 2016 Report Posted April 29, 2016 Purchased a supposedly nearly-new Dewalt 788 within the past year. We haven’t used it much at all yet. Noticing that the motor is bogging down when blade tension is increased. What do I need to know to overcome this motor bog down issue? Quote
ike Posted April 29, 2016 Report Posted April 29, 2016 I have the same machine in fact 2 but never had that problem. Ssorry IKE Quote
DWSUDEKUM Posted April 29, 2016 Report Posted April 29, 2016 I am wondering if the motor might not be bad. I have had a Dewalt 788 for a fairly long while and I have never had it bog down when tension is applied. It is under warranty? You may wish to call your local Dewalt Service Center and talk to a technician - http://www.dewalt.com/Find-Service-Center.aspx Let us know what you find out if you will. DW Quote
Jim Finn Posted April 30, 2016 Report Posted April 30, 2016 I have a friend that killed a Dewalt motor every year for five years untill he finaly tossed it. He was cutting 1 1/2" thick wood, making toys. I guess the DeWalt does not hold up well under hard usage. This may have been how your motor has been used. Quote
amazingkevin Posted April 30, 2016 Report Posted April 30, 2016 I googled the problem,nothing came up for the Dewalt but for other electric motors it ended up it was the motor self destructing Quote
NC Scroller Posted May 2, 2016 Report Posted May 2, 2016 You should not start your saw with zero tension on your blade. Does the machine run fine with a tensioned blade in it but not contacting wood? Quote
CharleyL Posted May 5, 2016 Report Posted May 5, 2016 If the motor control board has a problem, it will do this, but it could also be the motor. Only electronic testing of both can determine which is bad. Can you use a screwdriver and turn the motor shaft easily while the power is off? There shouldn't be much resistance when spinning the motor this way, unless there is a bad bearing or something rubbing the mechanism inside the case. If mechanical resistance to turning the shaft is encountered, then this may also be the cause. Charley Quote
