amazingkevin Posted May 16, 2016 Report Posted May 16, 2016 planed the wood i glued yesterday for a 12" heart two 6" 1" thick aromatic cedar glued up yesterday.here's the pattern i'm glueing to the woodAnd the waste wood after cutting out i redid this one after misssspelled twice and then a new job today two large holes2.5" the rest 1.5" and then a 3/4" africas in plywood and an order for pennies with two holes in each-!/16" drill bit beveled with an 1/8 " bit to clean up the edge of the holes both sides a 2" africa with forstner drilled holes lawson56 and Smudger 2 Quote
Lucky2 Posted May 16, 2016 Report Posted May 16, 2016 Kevin, doing all that cutting, is sure to keep you out of mischief. What type of blade did you use to cut the heart out with, I notice a lot of rough edging on the back of the heart? Maybe it's the wood, what type is it? Len Quote
Ninuninu Posted May 16, 2016 Report Posted May 16, 2016 Lots going on Kevin... didn't get the pennies and Africa though! Tony Quote
lawson56 Posted May 16, 2016 Report Posted May 16, 2016 Same here a Little lost with the Pennies Africa thing.The name is Fantastic. Love the Heart. Quote
Gordster Posted May 16, 2016 Report Posted May 16, 2016 Very nice Kevin...you might say you gave it your 2 cents Quote
amazingkevin Posted May 16, 2016 Author Report Posted May 16, 2016 Whew, wow, What. Looking good. thanks LarryEA ! Quote
amazingkevin Posted May 16, 2016 Author Report Posted May 16, 2016 (edited) Kevin, doing all that cutting, is sure to keep you out of mischief. What type of blade did you use to cut the heart out with, I notice a lot of rough edging on the back of the heart? Maybe it's the wood, what type is it? Len That blade was a scroll reverse#12,the wood was 1" aromatic cedar.I probably didn't plan it enough on the back,Lord knows i love mischief too!Thanks ! Edited May 16, 2016 by amazingkevin Quote
amazingkevin Posted May 16, 2016 Author Report Posted May 16, 2016 Lots going on Kevin... didn't get the pennies and Africa though! Tony the lady wants to make a pennies necklace and the Africa thing is a way of counting money plus she uses it to display precious stones for sale in. Ninuninu 1 Quote
amazingkevin Posted May 16, 2016 Author Report Posted May 16, 2016 Same here a Little lost with the Pennies Africa thing.The name is Fantastic. Love the Heart. the lady wants to make a penny necklace,and the holes are like an abacus,to count money,she also displays precious stones in them,Thanks! lawson56 1 Quote
amazingkevin Posted May 16, 2016 Author Report Posted May 16, 2016 Very nice Kevin...you might say you gave it your 2 cents I held the pennys while drilling so i had to drill fast as the heat build up comes on fast.i go back with a bigger drill to clean up the hole from burrs.Thanks Bobby! Quote
DWSUDEKUM Posted May 16, 2016 Report Posted May 16, 2016 Busy as usual Kevin. Those look great. Thanks for sharing thee with us. They make a penny sized forstner bit I seem to recall. DW Quote
Ninuninu Posted May 16, 2016 Report Posted May 16, 2016 the lady wants to make a pennies necklace and the Africa thing is a way of counting money plus she uses it to display precious stones for sale in. Ok fair enough... makes much more sense to me now. It the rapid loss of brain matter on my part you see! Tony Quote
wombatie Posted May 17, 2016 Report Posted May 17, 2016 Kevin why do you have a map of Australia????????????????? The back of the heart looks a bit rough, was it the blade that you were using? Marg Quote
amazingkevin Posted May 17, 2016 Author Report Posted May 17, 2016 Busy as usual Kevin. Those look great. Thanks for sharing thee with us. They make a penny sized forstner bit I seem to recall. DW I think my forstner set goes down to 3/8" and i wish i could find it as i have a job i need it for right now! Quote
amazingkevin Posted May 17, 2016 Author Report Posted May 17, 2016 Ok fair enough... makes much more sense to me now. It the rapid loss of brain matter on my part you see! Tony lol! Quote
amazingkevin Posted May 17, 2016 Author Report Posted May 17, 2016 Kevin why do you have a map of Australia????????????????? The back of the heart looks a bit rough, was it the blade that you were using? Marg Oh ,that,The planer has nicks in the blade and the scroll saw blade must have been loose to.Its africa Quote
Dave Monk Posted May 18, 2016 Report Posted May 18, 2016 Busy! Busy! Busy! Keep it up! dave amazingkevin 1 Quote
amazingkevin Posted May 19, 2016 Author Report Posted May 19, 2016 Busy! Busy! Busy! Keep it up! dave thanks Dave it 's all i can do i'm wore out way over weight Quote
