Hi i have been cutting spoons on my scroll saw and then power carving them and power sanding i was wondering is there aother oil beside Mineral oil that i can use on the spoons I cut them out of walnut wood . I don't want to use a oil that someone may be allergic too.
I've heard olive oil may go rancid after awhile. I know a lot of people avoid using it on cutting boards. I don't have experience with it though. Butcher block or salad bowl oil is used a lot in food grade items. A lot of times you can find them at the grocery store. I also find it at the Big Box home improvement stores in with their other oil finishes.
Yep olive oil does go rancid after awhile..........any oils like that will.......canola, vegetable, etc... I'm not sure what oil you would use. If it's something that is used alot then I would think cooking oils would be fine as long as they were washed frequently and reoiled.....otherwise I don't have a clue. Sorry.
Christina
