Just wondering what speed you guys use on the mini bird houses, I been having trouble cutting them with  Popular wood, which I glued together, and using FD ultra reverse blades, sorta tried others and still having problems. any suggestions  would be helpful.  edward
When using reverse tooth blades for compound cutting, the dust can tend to clog up in the kerf, generating heat and shortening blade life.  Skip tooth blades generally work a little better as they clear the sawdust from the kerf more effectively than reverse tooth blades.
I have used all the blades above over time and like the polar the best. The big thing is I keep saying to my self thickere wood slow down, no hurry take your time. That does not always keep me from trying to force the cut but helps. Take breaks to get back to slow patient feed.
I use #5 and #7 Polar blades on my compound birdhouses.  I put clear packing tape on all four sides of the block and I have my saw running at full speed .
One point I want to bring up. You are using glued up lumber.  The glue could be your problem.  Most glues are harder then the surrounding wood and thus will lead to added fiction and rapid dulling of the blades.  The same problem happens with plywood.
Yes skip tooth blades speeds up cutting tremendously
Edward, any skiptooth blade should work fine, two-way cut blades work well for this type of cutting also. Try a few different types of blades, you'll soon settle on the one that works best for you.
Len
I HAVE CUT DOZENS OF THESE MINI BIRD HOUSES.  LAST BATCH WAS USING POPULAR....  USING THE 1.5 THICKNESS THEY
CALL FOR DID GIVE ME PROBLEMS.  I RIPPED THE BLANK DOWN TO 1.25" AND STILL ONLY USE THE ....FDUR #1 BLADE.
CUTS PERFECTLY FOR ME AND I HAVE MORE CONTROL WITH CHANGING DIRECTIONS DURING THE CUTTING PROCESS.
JUST MY 3 CENTS....................Danny  :+}
OH YEA....  HAVE TO REDUCE THE PATTERN DOWN A TAD....
