amazingkevin Posted June 9, 2016 Report Posted June 9, 2016 I'm a good one at this,I cut 100 birdhouses and predrilled the holes.well i took a trip to the big box store for perches and they didn't have the size i drilled the holes for.Live and learn the hard way.Measure twice drill once.I do the same thing on assembling new tools or what ever ,don't read the instructions ,that will slow me down.I'll just dig in look at the completed picture and go from there.not good. Phantom Scroller 1 Quote
Denny Knappen Posted June 9, 2016 Report Posted June 9, 2016 Kevin, I use wood skewers found at Walmart. Works great. Just make sure you use the right size drill. Quote
cmarsch Posted June 9, 2016 Report Posted June 9, 2016 Use a slightly bigger dowel than the hole you drilled and taper the end by sanding a bit to fit in the hole like a wedge. Apply some glue and insert. amazingkevin 1 Quote
Lucky2 Posted June 10, 2016 Report Posted June 10, 2016 Kevin, what size hole did you drill, maybe you could make custom perches? I know it would be more work, but, it would help finish them up. Len Quote
amazingkevin Posted June 10, 2016 Author Report Posted June 10, 2016 What size drill was you looking for? IKE I used one that was the same size as on the pattern.Ends up 3/16? is supposed to be 5/32" but i found on ling the other big box store carrys that size just a mile away Quote
amazingkevin Posted June 10, 2016 Author Report Posted June 10, 2016 Kevin, I use wood skewers found at Walmart. Works great. Just make sure you use the right size drill. After all these year i'm still learning,lol Quote
amazingkevin Posted June 10, 2016 Author Report Posted June 10, 2016 Whoops !!! Boy you got that right,lol Quote
amazingkevin Posted June 10, 2016 Author Report Posted June 10, 2016 Use a slightly bigger dowel than the hole you drilled and taper the end by sanding a bit to fit in the hole like a wedge. Apply some glue and insert. Yeah a quick hit on the sander will fix it! thanks ! Quote
amazingkevin Posted June 10, 2016 Author Report Posted June 10, 2016 Kevin, what size hole did you drill, maybe you could make custom perches? I know it would be more work, but, it would help finish them up. Len I was even thinking of real twiggs ???? WayneMahler and Lucky2 2 Quote
