Tino Posted June 12, 2016 Report Posted June 12, 2016 Some where I read about of formula for calculation the % of reduction by dividing the width of the pattern by the width of the board or something like that. Does someone know this formula or do you know where I can find it. TIA Tino amazingkevin 1 Quote
Dan Posted June 12, 2016 Report Posted June 12, 2016 I believe if you divide the width of the board by the width of the pattern you will get your answer. If the board is 18" and the pattern is 24", then 18"/24" = 0.75. So you would reduce the pattern from 100% to 75%. WayneMahler and NC Scroller 2 Quote
amazingkevin Posted June 15, 2016 Report Posted June 15, 2016 I believe if you divide the width of the board by the width of the pattern you will get your answer. If the board is 18" and the pattern is 24", then 18"/24" = 0.75. So you would reduce the pattern from 100% to 75%. I wish i understood math .It seems so simple only 9 numbers and a zero BUT...... Quote
heppnerguy Posted June 15, 2016 Report Posted June 15, 2016 When I need to increase of decrease a pattern, I simply open it on Inkscape, put my dimensions on inches and drag the corner of the pattern until is fits the inches I want. Seems like an easy solution to me but percentage I have never worried about.. Now I know how to figure it, should I need to, because of the question and answers above Dick heppnerguy Quote
Denny Knappen Posted June 15, 2016 Report Posted June 15, 2016 I use Photoshop in the print preview mode. This gives the size and you can reduce or increase as needed. Quote
Sycamore67 Posted June 15, 2016 Report Posted June 15, 2016 I bring the image into PowerPoint and manipulate the size. Quote
Lucky2 Posted June 16, 2016 Report Posted June 16, 2016 I use my printer to figure out what size to print a pattern, I reduce or enlarge by certain percentages. Once reduced/enlarged to the set percentage, you get the actual measurement size off of the image. It's a bit of trial and error, but, I always end up with the size I want. And it takes very little time to do. Len Quote
