joe966 Posted June 22, 2016 Report Posted June 22, 2016 So I have been doing some compound cutting on 1 3\4 x 1 3\4 blocks. I have tried multiple blades. I would like to get everyone's opinion on this. What do you think is a good blade for this? I have tried #7 modified geometry with horrible success. Moderate success with the #7 skip tooth and have found that a FD #1 ultra reverse works best for a fast cut without burns. I would think that the thicker blade on thick stock would be better, based off of what I have read but it seems that this is the opposite. Any opinions would be great. Thanks amazingkevin 1 Quote
Scrolling Steve Posted June 22, 2016 Report Posted June 22, 2016 In the past (in 1 1/4 and 1 1/2 stock ) I have used FD ultra reverse # 5 blades....From what i have read here I am going to try FD Polar blades for compound cuts. Jim Finn 1 Quote
amazingkevin Posted June 22, 2016 Report Posted June 22, 2016 So I have been doing some compound cutting on 1 3\4 x 1 3\4 blocks. I have tried multiple blades. I would like to get everyone's opinion on this. What do you think is a good blade for this? I have tried #7 modified geometry with horrible success. Moderate success with the #7 skip tooth and have found that a FD #1 ultra reverse works best for a fast cut without burns. I would think that the thicker blade on thick stock would be better, based off of what I have read but it seems that this is the opposite. Any opinions would be great. Thanks I'm glad you posted this Joe.I like to cut fast and compound cutting has put the brakes on that for me.I've lot's more mini bird houses to cut and i want to cut them fast.So far the skip tooth is working much better than the scroll reverse blades i've been using..well shortly now your going to get your answer as more of us will chime in on their knowledge of cutting thick wood.Thanks again for asking. Quote
SCROLLSAW703 Posted June 22, 2016 Report Posted June 22, 2016 (edited) +1 what Steve said. Polar blades work great for compound cuts. They cut clean, & leave a smooth finish. Some speed adjustment may be needed, depending on how intricate your project is, & the thickness of the material. Edited June 22, 2016 by SCROLLSAW703 Quote
Denny Knappen Posted June 22, 2016 Report Posted June 22, 2016 I use FD Polar #7 for the birdhouses and #5 for the birds. The Polar blades remove the sawdust better and therefore less burning and binding. Jim Finn and Scrolling Steve 2 Quote
tonylumps Posted June 22, 2016 Report Posted June 22, 2016 So I have been doing some compound cutting on 1 3\4 x 1 3\4 blocks. I have tried multiple blades. I would like to get everyone's opinion on this. What do you think is a good blade for this? I have tried #7 modified geometry with horrible success. Moderate success with the #7 skip tooth and have found that a FD #1 ultra reverse works best for a fast cut without burns. I would think that the thicker blade on thick stock would be better, based off of what I have read but it seems that this is the opposite. Any opinions would be great. Thanks I have just started cutting not to long ago.But the Modified geometry are the only blades i have total eliminated from my blade collection so far joe966 1 Quote
Jim Finn Posted June 22, 2016 Report Posted June 22, 2016 I use FD Polar #5 for compond cutting. Scrolling Steve 1 Quote
ike Posted June 22, 2016 Report Posted June 22, 2016 I use both #5 and #7 olsons blades with good success. Quote
Lucky2 Posted June 23, 2016 Report Posted June 23, 2016 I use the FD Polar #5 for most of my compound cutting now, I used to use the two-way blades. Len Quote
