Hi guys and gals. I have this piece of wood with the bark around it and not sure what to do with it. It's been in my workshop for a couple of years so I figured I might as well try to make something out of it. It measures 10" high by 7 " wide. I was thinking something religious or some type of portrait. Any ideas. Thanks.
Edited by rdatelle
I stacked the walnut on top of the basswood. Made darn sure my saw blade was 90 degrees, used the smallest blade I have (don't know the size for sure, but I need a magnifying glass to see the teeth) cut thru both, then glue the backer on and drop the walnut in like a puzzle.
Thanks Chris. That's a good idea.
Chris , how did you get it into the wood . Is it cut into it.
You folks have great talent i wish i had ,Excellent work
Ralph, what's the rush? Just because you've had it for a couple of years, doesn't mean that you have to use it now. You could keep it a while longer, then you might find the perfect pattern for it.
Len
Chris, another question for you. I'm looking at your picture and wondering how did you get the small pieces of the face cut out. I don't see ant drill holes. Did you cut those out like a puzzle piece and then glue them back in.
