Sycamore67 Posted June 26, 2016 Report Share Posted June 26, 2016 (edited) Recently Kevin posted about his having problems with the FD Polar blades and they had such fine teeth like a hacksaw. I was interested so took a look at my FD blades including the Polar, the Scroll Reverse and Ultra Reverse. Here is a picture of the FD Polar Blades #5, #7 and #9., The #7 and #9 are both 14 tpi and the #5 is 16.5 tpi Next is the Scroll Revers blades #5 and #7 which are 13 and 10 tpi. And Finally the Ultra Reverse #5, #7 and #9 which are 15, 12 and 12 tpi. The Polar blades have the largest and most aggressive teeth and it is surprising that they are not cutting well. It is what I use for compound cuts. Perhaps, if Kevin is having problems and the teeth are like hacksaw blades, he got the wrong blades? Edited June 26, 2016 by Sycamore67 Scrolling Steve 1 Quote Link to comment Share on other sites More sharing options...
dgman Posted June 26, 2016 Report Share Posted June 26, 2016 It's funny how one blade works for some and not others. For me, FD UR blades just don't work for compound cutting, but Polar blades do. Regardless of blade type, it is still slow going cutting thick wood. You cant force the cut, you have to let the blade do the cutting. Blades don't last very long either. Depending on hardness of the wood being cut, I can get three to five bird houses per blade WayneMahler 1 Quote Link to comment Share on other sites More sharing options...
Denny Knappen Posted June 26, 2016 Report Share Posted June 26, 2016 I use the FD Polar blades for compound cutting because they seem to eliminate the dust collecting therefore the binding. Scrolling Steve 1 Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted June 27, 2016 Report Share Posted June 27, 2016 I use the FD Polar blades for compound cutting because they seem to eliminate the dust collecting therefore the binding. Denny i have tryed the fdur#9 blades too and cut so slow. Quote Link to comment Share on other sites More sharing options...
Lucky2 Posted June 27, 2016 Report Share Posted June 27, 2016 Kevin, I think that your "so slow" may still not be slow enough. It's like been stated, you have to let the blade do the cutting without forcing it. Where did you buy your blades from, is there any chance of returning them for a refund or exchange for the UR type blades? Len Quote Link to comment Share on other sites More sharing options...
